ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      12-06-2007, 11:02 PM   #1
MMMazing07
More than you can afford pal....ferrari
MMMazing07's Avatar
181
1,471
Drives: Z4M
H &R springs
i am planning to order H&R springs. Does anyone who have them vouche that they actually improve handling? i want better handling but coilovers would be too aggressive and wayyyyy too low. it says that they only lower an inch so that is resonable.
      12-07-2007, 12:22 AM   #2
BimmerZealot
61
1,210
Drives: 2019 BMW X3 xDrive30i
No idea on the H&Rs personally; but, I've heard they are pretty rough when it comes to ride, even more unbearable then the OEM suspension which we all know is stiff as it is. My GF just got me a set of Tein S.Tech for my car, they are 0.6"/0.7" drop which is not as substantial as most lowering springs so I'm assuming it wont affect it too much
      12-09-2007, 07:50 PM   #3
danlauz
134
Drives: z4m 2007+x5 2009+330 cic 2003
detail
I just put back the the OEM springs on my z4m coupe (same model number also for the HR springs for both coupe and roadster). i prefer the ride on the oem. as for the look, its different. if you want the HR springs, send me a pm, I will find a deal with you. they are in perfect shape. they were on the car only 4000 km.
thanks
      12-10-2007, 02:53 AM   #4
GP20
99
1,269
Drives: Z4M, F80 M3, 991.2 GTS
The H&R springs I had were stiffer than stock but not harsh at all. They improved the handling very slightly. The thing I didn't like about the H&R springs was that their claimed 1" drop was more like 0.6"". The front wheel gaps still had a little more than 2 finger widths and visually they just didn't make enough difference.
And what do you mean that coilovers would be way too aggressive and way too low? If you want the best ride comfort, coilovers are the way to go (TCK or KW V3; don't bother with H&R coilovers which are crap). Lowering spring+OEM struts/shocks would never handle as well as a good set of coilovers with adjustible dampenings on a car like the Z4M. And you don't need to set the ride height low either. You can set the ride height the same as stock if you want, or basically play with the height settings until you're happy with them.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      01-02-2008, 07:10 PM   #5
sketchmunky
sketchmunky's Avatar
17
Drives: 2008 Z4 3.0si Coupe
I'm also checking out H&R springs as well. Are their 1.5"/1.25" drop accurate?
Also, how are those Tein S springs working out? Did you notice a visual difference or does it still look stock height?
      01-02-2008, 07:54 PM   #6
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
4,333
Drives: 2007 M Coupe
I think the stock setup can be harsh...the road around here are a pothole haven tho...
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      01-03-2008, 02:30 PM   #7
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
66
2,006
Drives: 2006 Z4MC Interlagos
Drop is ~ 1 " and I recommend using the OE rear spring pads to even front to back out.
The ride IMO is better than OE, feels more sure footed under cornering load, less "bouncy" over road imperfections. I like em - at first I felt the front suspension was a little too harsh, perhaps just because the springs had not settled.
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
      01-03-2008, 03:04 PM   #8
inTgr8r
inTgr8r's Avatar
2435
11,669
Drives: M2 Comp
^WHS +1
The OE are more of a progressive rate spring than the H&R.
I don't like progressives as they transition, especially under cornering loads.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      01-03-2008, 07:30 PM   #9
GP20
99
1,269
For the regular Z4, nope the H&R 1.5"/1.25" aren't accurate either. I had them on my '04 3.0i and the ride was absolutely slammed. Zero finger width gap at the rear and about slightly less than 1 finger width gap at the front. The drop was closer to 2" than 1.5". The car bottomed out going over every single bump.
2016 BMW M3
2008 BMW Z4M coupe
      01-03-2008, 11:56 PM   #10
sketchmunky
17
Thanks for the response! I was about to order a set. I think I'll stick to Eibach springs. One other person said that it was decent for springs.
      01-04-2008, 12:56 AM   #11
GP20
99
1,269
Make sure you get Koni adjustable struts/shocks at the same time. Getting them now will save you more money later on. Stock struts/shocks don't match well with aftermarket lowering springs and will give you a bouncy ride (when you accelerate or brake you will feel like a bobble-head doll). On my '04 3.0i I made the mistake of not getting the Koni struts/shocks at the same time because I wanted to save money. Couldn't stand the ride and few weeks later I ordered the Koni's and had to pay for a 2nd installation/alignment. Eibachs + Koni's will give you good handling performance and good ride comfort.
2016 BMW M3
2008 BMW Z4M coupe
      01-04-2008, 10:43 AM   #12
sketchmunky
17
Good point! However, I'll be doing the install myself and the big gap with my new wheels is driving me crazy! I have the equipment and have lowered quite a few cars before, so I won't mind doing the work again in a few months when I get the shocks. It's the same old story, too many mods to do and not enough money!
zpost
