M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      03-24-2014, 06:57 PM   #1
skypx
Veteran U.S. Army
skypx's Avatar
Germany
62
771
Drives: ///M
Mid cycle oil change
So I'm about to get the mid cycle oil change done and from what I've read on the forums the F10 M5 takes 9 quarts? Is that exactly 9 quarts or should I get an additional quart?
      03-25-2014, 08:21 AM   #2
skypx
Veteran U.S. Army
skypx's Avatar
Germany
62
771
Drives: ///M
Found the answer, 8.9 quarts. Thanks.
      03-25-2014, 03:32 PM   #3
v3n0m
59
451
Drives: 2013 MCB M5
Are you doing this yourself? Would you mind posting some pix or a DIY of the process or things to watch out for?
      03-25-2014, 03:45 PM   #4
skypx
Veteran U.S. Army
skypx's Avatar
Germany
62
771
Drives: ///M
No I going to have it done at the dealership. Sorry. I'm going to try the Mobil 1 synthetic 0W-40.
      03-29-2014, 06:55 PM   #5
avlnch
129
1,622
Drives: 2013 Individual M5
The M5's are filled up with BMW/Castrol 5W-30 at the factory. Knowledgeable dealers will put 5W-30 into the car during oil services. There have been multiple instances where dealerships put incorrect weights in the cars. So it's always a good idea to check on what they will use, or to bring your own oil to them.
I would recommend 0W-30, Castrol brand, European formula (often referred to as German Castrol).
German Castrol 0W-30 (code 06244) can be purchased from amazon. After you buy it, just verify it says European Formula on the bottle before you use it.
I am currently using 0W-30 since my break-in service. A few other members on here are using this as well. The car warms up faster, and some say the motor runs quieter at idle.
BMW recommends owners to always use Castrol brand oil. You can put any brand (meeting correct specs such as LL-01) fully synthetic 0-40 in the car, as it's an approved alternate weight for the S63TU engine. However, I would recommend Castrol brand, and would recommend 0W-30 weight.
2013 BMW INDIVIDUAL ///M5 {Frozen Black/Amaro Brown/Amaro Brown Alcantara/White Contrast Stitching/Piano Black Trim}
      03-29-2014, 07:29 PM   #6
avlnch
129
1,622
Here is what Castrol 0W-30 looks like.
      03-29-2014, 09:42 PM   #7
skypx
Veteran U.S. Army
skypx's Avatar
Germany
62
771
Drives: ///M
Thanks for your insight avlnch! There is so much debate nowadays in regard to engine oil, so I thought why not try it, its cheap!
So far using Mobil 1 is just an experiment, but I gotta tell ya, I'm loving it!
This is what I have seen so far.
Engine warms up quicker.
I'm getting better MPG.
Turbos running cooler. (I had to do a Google search to make sure the turbos are oil cooled) The fan(s) are quieter after shutdown with multiple pulls over 100mph!
So far the engine seems to be running more efficiently, but I'll see how it holds up in 8000 miles.
      04-26-2014, 06:00 AM   #8
GarbageMan
38
305
Drives: 2014 M5
Why? Because BMW has a marketing agreement with Castrol? This is no different than MB AMG's alliance with Mobil 1, and not the best reason to use as a determinant for oil selection...
m5post
