12-30-2013, 05:12 PM | #1 |
38
Rep 305
IPhone 5S operation with the adapter
OK, I've looked for this in the manual, to no avail at this point, and used the search function here. Can someone steer me to some info related to using my iPhone in the new M? If I'm using the wrong search term, pls put me on the thread. Thanks. I'm currently just linking up using Bluetooth...
12-30-2013, 07:24 PM | #3 |
178
Rep 1,155
There's nothing to it, really. What specifically are you trying to figure out?
If you have bluetooth working, that should already be good for music via bluetooth audio and telephone functions. You can get further functionality, and ostensibly better audio quality (though I can't tell the diff) by connecting your iPhone using your lightning to USB cable to the USB port in the armrest storage compartment. When connected this way you can use the BMW Connected Drive app to do a few more things (which are generally useless imho) as well as certain apps which recognize they are connected to your car and present their interfaces via iDrive (Pandora, MOG, Spotify, and others).
2017 Porsche 911GTS - Agate Gray on Black
2009 Aston Martin DBS - Casino Royale Gray on Black (sold) 2014 M5 ZCP - Azurite Black over SSII Full (gone) 2009 M5 - Carbon Black over Sepang Full (gone - not forgotten) 2001 740i M-Sport - Carbon Black over Black (gone - not forgotten) |
12-30-2013, 08:06 PM | #4 | |
38
Rep 305
12-30-2013, 08:43 PM | #5 |
19
Rep 184
Just tested wife's iPhone 5S and it does not fit in the snap in adapter correctly. My iPhone 5 fits fine.
Looks as if it was not designed to fit the 5S curved sides. |
12-30-2013, 08:47 PM | #6 | |
38
Rep 305
1. Am I out of luck? 2. You have a problem dealing with rednecks?... Or both... |
12-30-2013, 09:30 PM | #7 | |
Civilian
13
Rep 158
Drives: 2016 Mineral Grey M4 F82
http://f10.m5post.com/forums/showthread.php?t=890932
2016 F82 M4 - Mineral Grey
2009 911 Turbo - White |
12-31-2013, 03:02 AM | #8 | |
38
Rep 305
12-31-2013, 05:10 AM | #9 |
19
Rep 184
You may be out if luck with the snap in adapter and the iPhone 5S as far as 'snapping' it properly in place. However, connection via a lightning cable to the car's USB should yield the same functionality...minus holding into place of course.
12-31-2013, 07:36 AM | #10 | |
Knight Commander
563
Rep 5,948
Drives: 2014 911 Turbo S
Maybe your wife has an iphone 5C. That's the one with rounded edges. To quote a review article of the 5S: "The iphone 5S looks almost exactly like the iPhone 5 did, including its razor-thin aluminum body, with flat back and chamfered edges. It even weighs the same feathery 112 g (3.9 oz). The only visible differences between it and last year's iPhone are its new home button, a dual LED camera flash, and two new colors (space gray and gold join the 2012 carryover silver)."
2022 Mercedes-Benz EQS 580
12-31-2013, 07:45 AM | #11 | |
38
Rep 305
This is what I was thinking when I originally posted my question. I think half (or probably more) of my issue is user error. I couldn't find any info on it it the owners manual. How do I make the thing "hug" the phone? |
12-31-2013, 07:48 AM | #12 |
Knight Commander
563
Rep 5,948
With my 5S the fit is tight. Once it snaps in (you push it down and the clip moves up to accommodate it and then snaps back over the phone). The phone won't move around, it's gripped by both the lightning corrector and the snap in clip. Plus the sides also grip the phone in the corners. Are you sure it's a 5S you are using?
12-31-2013, 08:12 AM | #13 | |
38
Rep 305
12-31-2013, 03:32 PM | #16 | ||
19
Rep 184
12-31-2013, 03:34 PM | #17 |
19
Rep 184
12-31-2013, 08:01 PM | #18 | |
Knight Commander
563
Rep 5,948
When Apple launches the 5" iphone next year then I don't think the car will accommodate a dock for a phone that big either.
01-26-2014, 02:08 PM | #19 |
Commander
14
Rep 147
Drives: '14 M5 CP & '14 X5 50i
iPhone 5 (5s) 2014 BMW Adaptor
Hello stealth.pilot,
Here are some pictures of a iPhone 5-5s cradle I just picked up for my Wife's '14 X5 5.0. This is the "new" model with the fan installed. FWIW - In my '14 M5 I have the older model that has no fan. I've had no issues with it; however living in Southern Utah on 105F days the phone does get hot but does not stop working. I have an AT&T 5s that I leave in the car cradle at all times and another AT&T 5s that I carry. On several occasions I will forget my carry phone and then at least I have phone in the car as backup. It may seem obvious; however you must pull out the blank that comes with the car from the factory in order to install the cradle.
01-26-2014, 02:15 PM | #20 |
Commander
14
Rep 147
Two solutions Garbageman,
Sync via blue tooth OR put your phone in the cradle (see my last post) and it will automagicly work!
