09-30-2007, 02:51 PM | #1 |
21
Rep 119
V1 Hardwire--need instructions!
I desperately want a V1 in my M Coupe, but I really don't want that power cord hanging down.
I've searched every forum, but I cannot find good instructions on how to tap into the mirror wiring to hardwire the detector. I would be extremely grateful if someone could provide detailed instructions! Thanks in advance.
2007 Z4M Coupe--GONE
Alpine White/Imola Red |
09-30-2007, 06:06 PM | #3 |
61
Rep 1,210
Pull out your center dome light fixture and inside you will see a wrapped up bunch of wires that leads down to your mirror, you have to cut back the insulation and find a wire within the loom I totally forgot what color it was. For my car I had to remove the mirror base and unplug the wiring harness to get enough slack to reach it from the dome light fixture slot. After that it was simple as taping, mounting the power box and putting everything back together.
09-30-2007, 07:47 PM | #4 |
21
Rep 119
Is the wire I need red and yellow? Seems like I found that somewhere. I'll search over on e9Xpost and see what I can find. I wasn't planning on doing it myself, but if it isn't difficult I think I'll give it a go.
I just don't want to screw something up!
09-30-2007, 08:04 PM | #5 |
21
Rep 119
Alright, I searched on the other site and found some good ideas. I like the idea of running the power to the fuse box instead of slicing into the mirror wires.
I'm going to see if I can figure it all out before I buy the detector. Seems like it won't be difficult if I can get the cord to the fuse box and find a good place for a fuse tap and a ground.
09-30-2007, 09:02 PM | #6 |
61
Rep 1,210
Most people just tap into a ignitioned wire within the mirror harness. It took me about 30 minutes from start to finish and it hasn't failed me yet. Flawless install too all you see is the wire coming out behind the mirror that plugs into the V1. I can do some digging and find what wire it is I tapped but red/yellow sounds right. I'll double check and let you know, its definitely a DIY job. Not hard at all.
10-01-2007, 01:16 AM | #8 |
231
Rep 1,066
Drives: 2015 X5 50i M Sport
Where did you guys get V1 and how much? When I check on the offical site there's so many options for V1, and I don't know whether I need all of them or not. In addition, for the price that you paid for, what did it come with?
2019 Cayenne Turbo
Gone but not forgotten: 2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport |
10-02-2007, 06:17 PM | #9 | |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
This was posted on Z4um before but since that's gone kaput, this is the only other place that I know of.
http://forums.bimmerforums.com/forum...ht=garage+door I love the sound of my own keyboard tapping, so I'm going to quote myself: Quote:
10-03-2007, 07:53 AM | #10 | |
21
Rep 119
10-03-2007, 08:31 AM | #11 |
18
Rep 892
Fusebox is the way to go, get the "add a fuse" tap from Autozone, I did it in my e92 and it was about a 15 minute job, and best of all no wire cutting. There is a post about it on e90post that has pictures and some detail, I would imagine it's very similar.
10-03-2007, 02:20 PM | #12 | |
1821
Rep 5,337
I run my wires on top of the map light because I'm lazy. Ideally, if you see behind the fuse box that has a green/blue wire, that's the slot you'd want to splice into (switch 2, 5mA fused power) |
10-03-2007, 07:08 PM | #13 | |
21
Rep 119
10-04-2007, 07:26 PM | #14 | |
1821
Rep 5,337
Just a personal pet peeve. If you're going to do something right, do it REALLY right. Otherwise just hack it up like me. |
10-06-2007, 01:23 PM | #15 |
21
Rep 119
I've delved a little deeper into this project, and I have some further questions.
Using a fusetap, does anyone know which fuse I should tap in to? I assume it is one of the 5A ones, but the little card in the box looks like Egyptian hieroglyphics. Also, I'm not sure I'll have room in the fuse box for the V1 hardwire adaptor and the fusetap. Not sure where to ground it either. The E90 boys have a terrific post for this job--but their fuse layout is different (they tap into the Homelink fuse) and it seems like they have a lot more room to work. I'm going to post over there as well, but thought some of you would have some input.
10-06-2007, 02:07 PM | #16 |
61
Rep 1,210
Why dont you guys just tap into the mirror wiring harness? Not only is it easy, it's literally right there..? The blue t-taps that are provided with the V1 are perfect for the job, even after removal a small strip of electrical tape covers up the only "damage" Also pulling down the map light takes a single flat headed screw driver, also doubles for removing the housing on the base of the mirror which gives access to the harness.
10-06-2007, 02:15 PM | #17 | |
21
Rep 119
But since you mentioned it, which wire should I be tapping in to? I'd love to see a picture of how this is done so I'll know what to do.
10-06-2007, 04:22 PM | #18 |
61
Rep 1,210
There was a thread that I used but I dont have it saved I'll try to find it. But you use the blue t-tap and tap into either a green/blue (key position 2) if you have premium package or lavender/red (key position 1 "accessory") either will work just fine.
First pop out the center map assembly with a flat head screw driver, unplug it from the wiring harness. You wont find the wire you need in the plug for the map light. The wiring harness you want will be tucked in the back of the hole which the map light fits into. The entire loom will be wrapped in black tape so you'll need to peel it back to find the wire you want. Clamp the blue t-tap onto the wire of choice give it a good squeeze so it splices and clicks. Plug the red spade connector on the V1 power box into the t-tap and then inside the same hole you should see TWO black screws, I used one of these as my ground, you'll see a black wire ending in a fork which you will place under the screw and put the screw back in. After that run your wiring for the power to the V1, you can squeeze it out between the gap in the roof/plastic lining and the windshield. Using the applied double sided tape, tape the power box and the wires safely inside and replace the map light fixture. Before this you'd want to power on the V1 to make sure it works. My car is also a lease and this was the easiest, quickest method so I went with it. I dont foresee any problems with taping it up when I'm done with the car. Also my car is an 07 Roadster so the inners behind your map light may be slightly different but you get the idea. Take a look, you'll see what I mean. |
10-06-2007, 04:31 PM | #19 |
61
Rep 1,210
Here you go, found the thread. Not too many pictures but if you read it a few times when you pull things out you'll see what it all means.
http://forums.bimmerforums.com/forum...light=hardwire |
10-13-2007, 02:26 PM | #20 |
21
Rep 119
Can't find the right wire in the mirror!
OK guys, I decided to tap the wiring harness in the mirror this weekend. I took the lights down and found the bundle. But I don't seem to have any of the wires that were suggested to tap! Both red/yellow and green/blue have been mentioned but I don't have either. The closest I have is a red and white wire that seems to have an occasional piece of yellow "paint" along it's length. I'm thinking that is the correct one, but I don't know. Here's what I've found, and a picture.
For reference, this is a 2007 M Coupe with premium package. blue/yellow, blue/white purple/white, brown/black brown/blue, red/white/yellow* green/white, black/gray green/brown, yellow/white red red/white
10-13-2007, 06:18 PM | #21 |
61
Rep 1,210
Do you see a green wire with yellow stripes? You may have to dig around in the wiring bundle to find the one you need. I think any of the mentioned wires will work I'll pull down mine in a bit and see which wire I tapped into.
10-13-2007, 06:38 PM | #22 |
21
Rep 119
I don't see a green with yellow stripe. I do have a purple/white which I've read works just fine if you don't have the premium package. Think I could tap this one? I appreciate the assistance.
