02-28-2013, 03:29 PM | #1 |
Supreme Allied Commander
3888
Rep 54,553
Drives: F80 M3
Forge Motorsport uprated Intercooler for BMW 1M
This uprated intercooler has been designed for the BMW 335 equiped with the N55 (single turbo), and 1M equiped with the N54 (twin turbo) 6 cylinder engine. Our criteria was to achive maximum efficiency whilst retaining a simple fitment. With our testing results indicating increased cooling of up to 30 degrees centigrade and the ability to install this on your driveway at home in under one hour, we have just what we wanted.
After considerable trials with different intercoolers cores, we found that the most efficient for these models, was a core of bar and plate design, and along with an overall increase in dimensions we have been able to improve the cooling ability and reduce the pressure loss across when compared to factory intercooler. In the construction we use CNC machined bayonet couplers which allow an easy plug and play install. The intercooler is supplied with easy to follow instructions and all the parts required. A reduction in coolong across the rev range with up t0 30 degrees centigrade differential. Installation instructions: http://www.forgemotorsport.com/media/FMINT1M.pdf $1100 Order here: http://www.hpashop.com/Forge-Motorsp...N54-335-1M.htm Last edited by HP Autosport; 01-03-2017 at 03:46 PM.. |
03-27-2013, 07:03 PM | #4 |
3888
Rep 54,553
Drives: F80 M3
05-02-2013, 12:00 PM | #6 |
3888
Rep 54,553
Drives: F80 M3
05-09-2013, 01:04 PM | #7 |
172
Rep 2,347
Nice #s this won't work with n54 135i with out cutting stuff?
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
05-14-2013, 12:35 PM | #8 |
3888
Rep 54,553
Drives: F80 M3
05-14-2013, 12:43 PM | #9 |
172
Rep 2,347
Awesome!
So it will fit the 135i? I was confused cause your site says 335i and m1 but if it fits with no problem I got to get one!
05-14-2013, 01:03 PM | #10 |
3888
Rep 54,553
Drives: F80 M3
05-24-2013, 08:44 PM | #12 |
3888
Rep 54,553
Drives: F80 M3
08-15-2013, 05:54 PM | #13 |
34
Rep 770
Am I missing something here? Or is the Forge 400 or more dollars over the ETS at a marginal increase in power increase? The test were done on different days and who knows what changed between that time, too.
But... damn it looks nice as hell. I think they are both solid units. Did you test the 7" ETS intercooler compared to this? I think that would be more fair for the money. Unless you did, then ignore this entire post. lol
| COBB E30 | VRSF DP's | ETS 5" FMIC | BMS DCI | 393 RWHP / 434 RWTQ |
08-15-2013, 07:05 PM | #14 | |
3888
Rep 54,553
Drives: F80 M3
No oil deposits in either unit. Yes, both are good units. I kept the Forge on my 1M because I am just tired of dealing with silicon couplers and t-bolt clamps that can be hard to access. |
08-20-2013, 12:45 AM | #16 |
3888
Rep 54,553
Drives: F80 M3
ETS is obviously the less expensive unit here, but if were up to me I would still spend the extra money to get a direct fit unit with slightly better performance.
11-12-2013, 03:00 PM | #17 |
3888
Rep 54,553
Drives: F80 M3
Even a better deal, Forge IC is 10% off until Jan. 6th and we have them in stock!
11-13-2013, 12:44 AM | #19 |
3888
Rep 54,553
Drives: F80 M3
11-13-2013, 03:16 AM | #20 |
41
Rep 307
i like it but i have few questions compared to other intercoolers who needed to cut a little from the connecting pipes , they look to have more diameters in the intercooler outlet pipe
like the ETS and the other FORGE intercooler , does it make difference in power gains or the air flow ? i like the stock looking and no cutting require IC but want to know if the others will gian more power and better air flow to the charge pipe |
11-13-2013, 03:50 AM | #21 |
195
Rep 1,317
I had one of these Forge FMIC's fitted to my N55 135i last February
OEM next to the Forge
2017 X5 4.0dSE ~ Atlas Cedar:Ind.Amaro Brown Merino&Piano Blk, Sport Auto, DHP, Comfort seats, Cold weather pack, HK audio, Electric towbar, Sun protection glass.
11-13-2013, 11:31 AM | #22 | |
3888
Rep 54,553
Drives: F80 M3
