08-08-2012, 07:57 PM | #1 |
Supreme Allied Commander
3888
Rep 54,541
Drives: F80 M3
Performance Friction 08 Compound for your E82 1M
PFC08 Compound is one of the PFC newest and have gained immediate favor in Endurance Sportscar, and GT racing due to its peformance in applications where smooth initial bite is a must. 08 have a slight friction rise with temperature, excellent release and modulation characteristics, and very low abraded disc wear. In addition to its considerable performance, 08 wears the longest of all PFC pads and easily matches wear of the other competitors with much higher bite.
BMW 1M fitment for both front and rear axles. $261.45 Front $249.67Rear Available now! Order here: http://www.hpashop.com/Performance-F...ompound-08.htm Last edited by HP Autosport; 08-21-2014 at 12:27 PM.. |
08-11-2012, 02:28 AM | #3 |
3888
Rep 54,541
Drives: F80 M3
08-11-2012, 05:55 PM | #4 |
85
Rep 313
I like to squeal like a school bus when i go to the track...cause everyone looks and they know im serious.
2024 X3 M40i
2011 1M Coupe VO (Sold) 2015 MB GLK 250 Blutec Deez (Sold) 2001 S54 M Coupe (Sold) 1998 M3/4 (Sold) |
08-12-2012, 12:25 PM | #5 |
3888
Rep 54,541
Drives: F80 M3
08-14-2012, 02:50 PM | #6 | |
33
Rep 1,035
I drove them 3 hours out of state for work this monday. Because they are full track pads there are no clips and no soft/rubber backing to them. The only time they squeal is with very light brake application at sub 7mph speeds and warmed up (ex. coming to a stop light). Its my understanding these squeal much less than the 01's and are much less abrasive on your rotors (In fact less abrasive than stock pads). You may be able to combat the squeal with CRC Brake Quiet if you follow the instructions and let it cure for 20 minutes before installing the pads. Personally, I can live with it until friday when I go to Lime Rock! All in all, GREAT deal on these sweet track pads and a GREAT vendor! |
08-15-2012, 03:45 PM | #7 | |
7909
Rep 11,785
any rattle from the pads in the caliper like the 01s ? |
08-16-2012, 03:37 PM | #8 |
33
Rep 1,035
I would assume it is possible because the pads have no backing, no clips, or anything else. Just the metal back of the pad and ears. They do fit snugly in the caliper once bolted back together, and although I wont be on the track until tomorrow morning, all week on the road they have not had any "rattle". They do squeal if you try and brake using very very light pressure (ex. rolling up to a light) but thats just the pads telling you you are not giving them the work out they want and deserve!
12-10-2012, 12:09 PM | #10 |
33
Rep 1,035
Wear wasnt bad after 1 event of pretty heavy use. Unfortunately my season was on hold after that so I dont have more info for you. These pads are great.
01-31-2016, 12:56 AM | #22 |
3888
Rep 54,541
Drives: F80 M3
