      06-07-2012, 02:59 PM   #1
Ryan@IND
Ryan@IND's Avatar
1771
7,653
Drives: ACR
iND | Macht Schnell MS97 Spec Shifter Knob
Finally, a more aggressive knob made for the BMW shift lever. The Macht Schnell MS97 knob stands at 97mm in height allowing for a more efficient shift motion all the while bringing the knob closer to the 3 o'clock hand position. As a result the driver can focus less on shifting the vehicle and more on steering input. The knob is machined using 6/6 nylon which means less heat transfer from the aluminum shift lever and reduced NVH.
The knob is a pressure fit and does not require any screws. For clients with the 1 piece OEM knob and boot modification/trimming is necessary.
Macht Schnell MS97 Spec Shifter Knob - $89.00 MSRP
IN STOCK AND READY TO SHIP!
  • SKU: 50.20.097
  • Black nylon 6/6 construction
  • 97mm height
  • BMWs with a 1-piece shift knob/boot will require modification
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
1addicts
