      04-14-2012, 05:44 AM   #1
formex_racing
formex_racing's Avatar
28
Drives: E92 335
Question KW V3 Height Adjustment issue....
Hi guys!
Need some KW experts out here to help me out.....
When set to lowest height settings, there is a difference of 20mm on the front shock body adjusters......
Is this normal?????
Alpine White 1M Coupe - everything stock except for the KW V3 coilovers.
Hope to hear from you guys soon......
Thanks!!!
Wil
      04-14-2012, 09:09 AM   #2
Franklin Joseph
57
820
Drives: BMW
are you talking about the distance between the shock and tires?
      04-14-2012, 09:21 AM   #3
formex_racing
28
Drives: E92 335
Nope.
Can you see the difference of the height adjuster from the 2 pic I posted?
Pics taken is left & right front setup.
Wil
      04-14-2012, 01:51 PM   #4
Franklin Joseph
57
820
Drives: BMW
got it but i'm still not understanding what you mean by lowest setting?
Both adjusters should freely adjust all the way up and down. When i had mine installed and set up here's my settings.
Street - distance from bottom of adjuster
driver side = 16mm
pass side = 14mm
Track
driver side = 20mm
pass side = 18mm
we kept a 2mm difference between driver and passenger side (assumption that i was driving alone with no passengers)
But 20mm difference is alot from one side to the other.
BTW, why are you running that cover over the springs?
      04-15-2012, 06:16 AM   #5
formex_racing
28
Drives: E92 335
driver side = 16mm
pass side = 14mm
Track
driver side = 20mm
pass side = 18mm
This is the lowest the adjuster can go for the left side.....
Tire to fender is the same gap for both sides but the right side adjuster still have 20mm more to play with.....
Just wanna know if this is normal as I know each corner of the car weighs differently & hence the adjusters on all four corners will have differences....
BTW, those black plastic hose covers helps eliminate spring rubbing sounds.......
Wil
      04-19-2012, 08:04 AM   #6
formex_racing
28
Drives: E92 335
Frank,
What's your front tires to fenders gap measurements both left & right side with the way you adjust the height from measuring from the inner front height adjusters??
Please sure.....
Any other bros with KW V3 care to share their settings on their 1M??
Wil
      04-19-2012, 09:17 AM   #7
Franklin Joseph
57
820
Drives: BMW
i dont own the 1M anymore so i cant get the measurements...sorry.
      04-19-2012, 09:30 AM   #8
formex_racing
28
Drives: E92 335
Thanks for the reply buddy.
Wil
1addicts
