10-27-2010, 08:57 PM | #1 |
Custom User Title
149
Rep 661
Stopping coil slap noise
Hello All -
I'm passing along this advice/experience in the hopes that someone else may benefit from our discovery via long period of trial and error. I had a recurring thunk/clunk coming from the left rear corner. It made a 'gronk' suspension noise that was rather loud and very annoying. Easily replicated in a quiet parking lot at 10-15mph by first loading and then unloading the left rear corner. Even a small bump would do it. I suspected worn bushings in the Rogue RSMs; bought a new set and replaced them. Noise abated for around 50 miles then returned. Both Rogue and KW were very helpful and responsive on support questions but we could not find the cause. Plug for Rogue and KW support. We eventually tracked the problem to the lowermost two coils of the KW spring rubbing together when loading/unloading that corner. The friction had worn through plastic factory outer sleeve (below), allowing the painted metal coils to bind/rub against one another, especially when that corner got unloaded, creating the noise. Despite being on the car only four months, the wear on the coils was visually obvious : Attachment 448399 On a tip from KW we tried wrapping the lowest coil of that spring with a layer of electrical tape, which temporarily eliminated the noise and confirmed the source. I finalized my fix with spiral-cut 'coil flex' cable minder, 3/8" size. Goes easily around the bottom-most coil or two and eliminates coil binding/noise. About $5.00 for ten feet at radio shack (link) or electronics /home supply store. Very easy to install/replace. The Coils cannot contact each other any more. 500+ miles so far of quiet driving Attachment 448418 Last edited by blender; 11-21-2012 at 10:31 PM.. |
10-28-2010, 06:56 AM | #4 |
2435
Rep 11,669
Good tip.
'21 M2C Hockenheim Silver
10-28-2010, 08:29 AM | #5 |
44
Rep 1,855
Will the springs chew through the coil wrap as it did the paint? How are they holding up so far?
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
Tags |
coil, noise, springs |
