10-19-2010, 07:55 PM | #1 |
Rep 47
DIY Stealth Bulbs
I recently purchased a set of stealth bulbs. These are supposed to remove the amber in the headlights. i was wondering if anyone has done this mod and if there are any DIY listings for this. Thank you.
10-26-2010, 12:22 AM | #2 |
keep it fast keep it furious
Rep 54
To get to the turn signal bulbs there's a cover in each fender well to remove and the bulb simply twists and pulls straight out, maybe 5 min job at max. Takes more time to get in the car, start it and turn the wheels.
10-31-2010, 05:53 PM | #4 |
Rep 47
Bav Auto
I purchased these bulbs from Bav Auto. I still do not really understand how to install them so if anyone has any more info, i would appreciate it.
11-08-2010, 12:01 PM | #5 |
80
Rep 803
Paul Walker above gave you the solution. If your wheels will not turn, or you do not have an inner liner on your fender wells, you should take the car in for service.
Objects in mirror are slower than they appear.
11-17-2010, 03:18 AM | #7 |
Rep 47
Orange ones inside the headlight
The orange bulbs im talking about are the ones inside the headlight. There is a small orange bulb in there and i cannot find a way to get to it.
11-19-2010, 03:59 AM | #8 |
3119
Rep 3,078
Drives: 2023 iX M60 Oxide
access is through the wheel well. You'll see a door in the well directly behind the headlight.
11-19-2010, 10:39 AM | #9 |
258
Rep 5,012
I don't believe you can get to that LED without taking the housing apart, but do a search; people have done it. And there's a vendor who does that as well. Fortunately, they look clear during the day, so I'm not bothered by them. Good luck.
11-21-2010, 05:43 PM | #10 |
Digger
209
Rep 2,619
I was under the impression that you can program it so that the amber lights will not run with the lights and only work with the turn signals. Am I correct in saying that?
2009 E92 M3 /// Melbourne Red /// Fox Red /// M DKG
Full Innotech Exhaust - DINAN Intake - IND Engine Bay Appearance - IND Hand Stitched Boot Covers - and much more.... |
