03-13-2010, 06:15 AM | #1 |
Rep 94
Drives: 2005 Z4 3.0i/SMG
No power for navigation unit
I just finished installing a factory navigation system in my 2005 Z4 3.0i, but I can't seem to get power to the NAV DVD unit. The retrofit instructions that I used indicated that pins 5 and 11 on the backside of the radio supply the power to the unit, but when I test those pins for voltage I get nothing. While I realize that my existing CPU needs to be re-programmed to know that a navigation unit has been installed, I would not have thought that the re-programming would have resulted in these two pins getting power. Does anybody know if that's true? The radio and CD function without issue.
Thanks, David |
03-13-2010, 03:01 PM | #2 |
89
Rep 847
You shouldn't need any reprograming. Is the ground cable connected? I had initially not connected the ground cable (it connects somewhere begind the driver seat IIRC) and w/o that there was no power. Once I connected it, everything worked fine.
03-13-2010, 03:53 PM | #3 |
Rep 94
I did connect the ground wire to a good metal stud that was holding my alarm tilt sensor. I didn't test to see if it was a good ground, but it looked good. Did you wire yours, and if so, did you use pins 5 and 11 on the backside of the radio? I posted this on another site, and was told that those two pins are for the voice signals from the Nav "turn right in...". I was told that the harness I need is already in place, on the passenger side of the storage compartment. Is that what you used? If so, I'm not exactly sure where I will connect it to, as bith available connection spots on the back of the Nav are now occupied. If my car was pre-wired, did I even need a separate wiring harness?
Any photos or instructions would be greatly appreciated. Thanks, David |
03-13-2010, 04:25 PM | #4 |
89
Rep 847
My car wasn't pre-wired so I did need to get an additional harness. I also did not need to do any rewiring. I will look @ the diagrams when I get back home.
03-13-2010, 09:14 PM | #5 |
Rep 94
Spaceman Spiff,
Thanks for your assistance. Can you verify whether your wiring harness and setup is identical to what is in this retrofit documentation? http://www.bimmerboard.com/members/joel ... trofit.pdf Thanks, David |
03-13-2010, 10:01 PM | #6 |
89
Rep 847
Your link is cut short but I think you mean this: http://www.bimmerboard.com/members/j...V_Retrofit.pdf
I bought the parts based on that TIS guide but used a post in an Italian forum for instructions. I still have the PDF print outs of the instructions that I used and I can email it to you. The TIS shows pins 5 and 11 but I can't tell where the wire's coming from. Could it be the steering wheel controls? I didn't have the MFSW when I was installing mine. It's also possible that I did rewire mine but can't remember it now since it was almost 2 years ago. The instructions that I have don't show any rewiring either! |
03-14-2010, 07:18 AM | #7 |
Rep 94
Yes, that's the correct link...thanks. I'm going to look for the wiring loom on TIS, but if you happen to have the part number I'd greatly appreciate it.
Thanks, David |
