      10-18-2009, 07:00 AM   #1
P'cisT
Australia
41
Drives: 135i
1 Series Hatch Wheel Specs?
Just wondering what the specs are? Stud pattern and offset? Doing some research on possible rims (:
Also, will 3 Series alloys be compatible?
Cheers.
      10-18-2009, 07:22 AM   #2
larryn
2148
10,176
Drives: '97 332ti, '21 X5 45e, '16 GT4
Check out this site: http://felgenkatalog.auto-treff.com/
It gives all the wheel specs for your car that you need.
You have a 5x120 bolt pattern.
oh! Welcome to 1addicts!
      10-18-2009, 07:30 AM   #3
Macca916
Macca916's Avatar
England
98
Drives: X6 XDrive35D
1 series hatch wheels are the same as the coupe.
e36 3-series including the M3 alloys fit as they have high offsets ET41 for the M3 alloys (note these are 17" standard factory fitment, not aftermarket)
e46 3-series could be ok excluding the M3 as this has a low rear offset (ET26?) beware aftermarket rims as they maybe too low an offset for the 1 but check offsets widths of the factory wheels too as they may be close to fenders (ie anything lower than ET40 and wider than 8" could be too tight .
E90 if you stick with the narrow 18" rims or 17" rims then it might be ok if the tyre size isnt too wide check some indicators of the sizes offsets here
http://www.akto.nl/OrgBMW/e90_wh.htm
Note use this as a guide as the E82/7 list on the same site has some errors in the offsets listed.
e36 M3 sunflower alloys in staggered 7.5/8.5" of ET41 offset work fine as winter tyre wheels. Pic here (wearing summer 225x45 and 245x40 tyres.)
1addicts
