09-01-2009, 12:06 AM | #2 |
//Mdicted
348
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
if this is anything like my last e90, which i believe it is, it involves dropping the rear sub frame to install the aft sway.. the fronts are ez. The rears are a Mother!@#$
but there is a technique to get around it, but i wouldnt do it as a backyard mechanic. I gave the tip to my mechanic and he got it right away and was able to do it all in 2 hrs, which normally would be a 4+ hours job
09-01-2009, 07:08 AM | #3 |
yodog
197
Rep 5,025
How much do sway bars cost to install on our cars?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
09-02-2009, 02:21 AM | #4 |
Bored at work....
893
Rep 5,395
Someone has swaybars for the M3?
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
10-05-2009, 10:17 PM | #5 |
74
Rep 610
I bought the e93 sways and installed the front. Pretty straight forward to install. Havent done the rears yet due to the whole sub frame issue
EDC.....viagra for your car
10-05-2009, 11:05 PM | #6 |
Moderator
675
Rep 4,737
Front is quite simple. Just drop the reinforcement plate and the bushings and you are done. The rears... don't do it. You don't want to mess with factory aligned suspension subframe just for a sway bar...
If you really want to do it, make sure a good, certified body shop aligns the subframe for you. |
