BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Suspension | Brakes | Chassis | Handling
European Auto Source (EAS)
      07-24-2009, 01:33 PM   #1
Ryan@IND
BimmerPost Supporting Vendor
Ryan@IND's Avatar
1771
7,653
Drives: ACR
WSTO - AP Racing Brakes for E9X M3
Competition is the best of test-beds, and AP Racing's years of close involvement with motorsport also bring benefits for the latest high performance road cars. The emphasis may be different, qualified by the everyday demands of modern road conditions, but the essential requirements remain the same.
with a dedicated Road Car team of engineers and designers AP Racing helps to bring extraordinary capability to extraordinary cars like, Ascari, Aston Martin, Caterham, Ford, HSV, Koenigsegg, Noble Morgan, Bugatti, Lotus, Seat, Spyker and TVR, to name a few.
Now, they have a kit for the E9X M3
Front 6-piston Caliper and Rear 4-piston Caliper
- Lightweight, pressure cast aluminum alloy 2pc body for better pedal feel than typical monoblock calipers
- Fixed radial mount for minimal caliper flex
- Hard anodized then finished with a tough 2-part paint system
- Differential piston bores minimize pad taper and maximize braking efficiency
- Secondary dust seals for everyday use
- Anti-Ratle clip to eliminate everyday use
- Compatible with OE ABS, Traction Control and ABS Stability systems
- Fits on OEM 18" and 19" wheels
Front 368mm x 36mm Rotors and Rear 356mm x 26mm Rotors
- Front: 2-pc strap drive assembly with aluminum hat
- Rear: 2-pc modular rotor floats on hard anodized aluminum hat (retain OE parking brake)
- 48 directionally curved vanes for maximum cooling
- cross-drilled and slotted for aggressive pad bite and better cooling
- Slotted only rotors optional for trackers
Brake Pads: Mintex Xtreme Motorsport Compound
- Extremely high friction for race pad stopping power
- Excellent grip - from cold to over 1300*F
- Liner and predictable under all conditions
Brakets
- Steel alloy mounting brackets for maximum strngth and stiffness
- Anodized for durability
Brake lines and Hardware
- Stainless steel outer braid with PTFE inner liner (DOT Compliant)
- High Performance hardware included
Please call for Pricing and to Build a set just for You!
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      09-12-2009, 04:19 PM   #2
dawgdog
150
2,278
Drives: 2015 M3, 2016 GT3
Julius could you PM me a price for front and rear.
Thanks,
Carl
2015 f80 M3, 2016 GT3
      09-13-2009, 11:23 AM   #3
TOOMANYCARS
TOOMANYCARS's Avatar
221
Drives: 2009 E92 M3
I know for sure these are a lot less than Brembo's, and less than Stoptech's. I had AP kit on my E60 few years ago, very nice product, new owner bought it mainly because of the brakes, he said he'd never seen an E60 with AP installed, and he was sick of seeing Brembo's all over.
Everything is work in progress.
      09-15-2009, 06:50 PM   #4
Johan@WSTO
201
2,117
Drives: BMW E89 Z4
PM sent! Thank you for your support!
      09-15-2009, 07:37 PM   #5
albert1028
Taiwan
20
390
Drives: 2009 E90 Space Gray M3
PM price of a set of AP racing for E90 M3.
Thanks!
      09-15-2009, 07:45 PM   #6
skierman64
skierman64's Avatar
127
3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
1994 325is Race Car  [0.00]
2011 BMW Z4  [0.00]
1998 M3 Coupe  [0.00]
2008 M3 Coupe  [0.00]
PM please, thanks.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
      09-16-2009, 06:40 AM   #7
dawgdog
150
2,278
Curious why JAJ mentioned in his post on the forum that a 10-12mm spacer was needed for the front with stock 18" wheels? Doesn't really apply to my situation but curious nontheless.
      09-16-2009, 04:27 PM   #8
Victory Road
114
1,323
Drives: BMW
Thanks!
Originally Posted by skierman64 View Post
PM please, thanks.
Sent you both a PM. Thanks!
I'm not too sure why either. Stillen/AP says they will fit under oem 18" wheels. They do provide a brake fitment template though to make sure if anyone is interested.
      09-18-2009, 06:30 PM   #9
Ryan@IND
Ryan@IND's Avatar
1771
7,653
Drives: ACR
We have been told by AP Engineers that the the AP Racing brakes were designed to fit on the OEM 18" wheels.
However, they just learned that the same design 18" OEM wheel has 2 different specs. the 18" built for the run flat tires have different internal design compared to the non-run flat 18" wheels.
The non-runflat wheels seem to clear the AP Racing bbk, but it is the runflat 18" OEM wheel that has spoke clearance issues.
we are continuously getting updates from AP. Will provide more information as we find them out.
      09-18-2009, 10:16 PM   #10
deamon
42
Drives: 2008 m3
Julius, please pm for e93 front and rears
      09-21-2009, 06:35 PM   #11
Victory Road
114
1,323
Drives: BMW
Hope you don't mind it being from Frank . Sent you a PM!
      09-22-2009, 06:12 PM   #12
Type-S
36
110
Drives: F82 M4/E92 M3/E82 1M
Could you PM me a price for a front kit? E92 M3
Thanks!
      09-23-2009, 11:24 PM   #13
Ryan@IND
Ryan@IND's Avatar
1771
7,653
Drives: ACR
Thanks!
Sent you the information.
for all BBK, we highly recommend going with a complete set up of Front and Rear if available.
AP Racing has engineered the product to have the correct amount of brake bias (front to rear) and just going with the fronts may result in diminished effective braking.
      10-19-2009, 10:59 PM   #14
doba_s
doba_s's Avatar
408
6,107
Drives: X7 l Cayenne l 997.2RS
price please front/rear. Thanks
      10-20-2009, 01:05 PM   #15
Ryan@IND
Ryan@IND's Avatar
1771
7,653
Drives: ACR
PM sent. Thanks!
      11-13-2009, 05:38 PM   #16
M-Maika
M-Maika's Avatar
Portugal
11
365
Drives: M3 E92 AW
2008 BMW M3 E92  [10.00]
PM please. Thanks.
M3 E92 M-DKG and all the options available.
Forum BMW Portugal: http://www.forumbmwportugal.com
      11-13-2009, 07:40 PM   #17
Fanta
C
Fanta's Avatar
51
722
Drives: 740iL, M3, Carrera
      11-13-2009, 08:39 PM   #18
turb934
turb934's Avatar
23
325
Drives: E92 M3
PM me a price for front & rear to Ontario Canada
08 E92 Interlagos blue, AFE filter, AA X-Pipe & HFC, AA pulley, AA software V1.5, Eisenmann race, M Performance Steering Wheel II, Pagid RS19's, Stoptech SS brake hoses, RAC RG63 Silver, Motul 600, E93 front & rear stablizer bars, M3 Competition Package Carbon Fiber Rear Lip Spoiler, Vorsteiner GTS3 carbon fiber front bumper & vented hood.
      11-13-2009, 08:42 PM   #19
KWY91
KWY91's Avatar
Singapore
37
1,297
Drives: 2015 BMW M3 (on order), 458
please PM price front and rear! Thanks!
Wanna know my mods for my 335i? It's here! http://www.e90post.com/forums/showth...ght=blue+water
Lamborghini's Mica Orange E93 M3
Akrapovic Exhaust //Challenge Rear CF diffuser//ESS VT-575 Supercharger
      11-16-2009, 01:41 PM   #20
Victory Road
114
1,323
Drives: BMW
Originally Posted by M-Maika View Post
PM please. Thanks.
PMs sent! Thanks for the interest!
      11-17-2009, 12:03 AM   #21
rzm3
Moderator
rzm3's Avatar
675
4,737
Drives: E92 M3
Please PM me price shipped to 77027. Thank you.
      11-17-2009, 12:13 PM   #22
Ryan@IND
Ryan@IND's Avatar
1771
7,653
Drives: ACR
PM sent. Thanks!
m3post
