06-15-2009, 12:44 PM | #1 |
BimmerPost Supporting Vendor
309
Rep 3,635
Drives: R56 Cooper S
▀▄ eas | Macht Schnell Competition Wheel Spacers DIY Instructions
There's a bit more to installing spacers than yanking the wheels off and sandwiching them between the wheels. Here's how to determine what kit is needed.
The outermost point of your tire/wheel combo will be at the outermost "bulge" of your tire's sidewall. Using a straightedge or ruler flush with both the top and bottom of the tire - measure the clearance from the outer face of the tire to the inner lip of your fender and record the results onto paper for later. In this picture, we can gauge the clearance using a tape measure (straightedge not shown): Next, begin by jacking up the vehicle and securing with jackstands. Remove wheel and clean hub of all dirt and/or surface rush with a wire wheel to ensure a clean and flush mounting surface, eliminating the chance of vibration: A small amount of anti-sieze on the hub lip will make spacer removal easier if needed: Macht Schnell spacer mounted to front wheel, ready for wheel mounting: Extended lugs must be used and are included with all Macht Schnell spacer kits. Secure wheel with new fasteners and torque to 85-90ft lbs, reinspecting after 50 miles. |
06-15-2009, 07:09 PM | #2 |
1253
Rep 6,917
Can you specify what type of anti-seize was used?
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
06-15-2009, 07:25 PM | #3 |
8277
Rep 18,861
Drives: BMW
Any type can be used - the specific brand used in our DIY was from Loctite.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
06-18-2009, 05:22 PM | #4 |
407
Rep 6,107
can you guys show us how to remove spacers ? It was very easy for me to install them ( just the way you described it) but it took me 2h to remove just the rear spacers ... it was like a nightmare ...
06-18-2009, 06:39 PM | #5 |
8277
Rep 18,861
Drives: BMW
Was the anti-seize used during installation?
06-19-2009, 06:51 PM | #7 |
8277
Rep 18,861
Drives: BMW
With anti-seize, removal should be a snap. A slight amount of pressure with a pry bar will unseat the spacers.
06-20-2009, 10:32 AM | #8 |
407
Rep 6,107
06-20-2009, 10:10 PM | #9 |
Commander-In-Chief
2203
Rep 8,949
Should have got REs! Seriously, get a tapered chisel and strike it at the joint. Should pop them off. A wood chisel would be best because of the acute angle tip.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
06-21-2009, 07:31 PM | #10 |
Critical Care Anesthesiologist
484
Rep 8,828
Drives: SMB F83
That was one of the reasons why I bought the RE spacers for my NEEZ wheels.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
06-21-2009, 07:50 PM | #11 | ||
8277
Rep 18,861
Drives: BMW
As stated earlier, a slight amount of pressure with a pry bar will unseat the spacers - good prepping and a small amount of anti-seize on the hub surface will all easier removal if needed.
08-27-2009, 09:32 PM | #16 |
8277
Rep 18,861
Drives: BMW
Who's removing them? We've been installing them almost every day on almost every M3 rolling through the doors.
08-27-2009, 09:49 PM | #17 |
Commander-In-Chief
2203
Rep 8,949
Don't weld them on next time!
02-28-2011, 03:01 PM | #19 |
Commander-In-Chief
2203
Rep 8,949
Any mod you do to your car could affect warranty, but its a long shot with spacers. Only thing I could see being blamed on them is increased wheel bearing wear. Individual tire shops may have a policy due to assumed liability related to poor fitting spacers. High quality hubcentric spacers do not typically cause issues, though I wouldn't go more than 10-12 mm max.
03-01-2011, 05:44 PM | #20 | |
22
Rep 499
03-01-2011, 06:33 PM | #21 |
Commander-In-Chief
2203
Rep 8,949
Spacers
No, 15 vs. 12 is only 1/8" difference. I went 12/12 with my stock wheels and I thought it looke fine.
10-13-2011, 06:55 PM | #22 |
8277
Rep 18,861
Drives: BMW
Thread revival - had a few questions on procedures!
