BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
      04-01-2009, 03:33 PM   #1
drvai
drvai's Avatar
138
1,274
Drives: E92 M3 AW
Brake change sensor
How does the computer in the car tell how much brake pads are left.
I have 7k miles and tells me it still has 20k to go.
How reliable is this? I donīt want to be overdue and destroy my rotors.
      04-01-2009, 07:17 PM   #2
lucid
lucid's Avatar
376
8,033
Drives: E30 M3; Expedition
It is most likely using accelerometer data to estimate pad wear. If you wear your pads beyond their operational threshold, a second system will be triggered--the physical pad wear sensor--and the red "brake" light that comes on when you turn on the ignition will not go away after your start the car. There is no reason to be concerned since you will get a warning either way before you reach some kind of critical state.
      04-01-2009, 07:31 PM   #3
Big Windy
Big Windy's Avatar
152
5,124
Drives: None
a bit OT, but have you ever noticed that the "brake" light initially comes on as yellow, then switches to red? i wonder if there is some type of brake diagnostic that occurs at startup. anyone???
      04-01-2009, 07:49 PM   #4
lucid
lucid's Avatar
376
8,033
maybe fluid pressure? i don't know...
      04-01-2009, 07:57 PM   #5
Big Windy
Big Windy's Avatar
152
5,124
Drives: None
south will know!
      04-01-2009, 08:31 PM   #6
lucid
lucid's Avatar
376
8,033
south will know!
yes, south to the rescue!!!
      04-01-2009, 08:39 PM   #7
JJM335
229
Drives: 2008 E92 M3
2008 E92 M3  [0.00]
There is a wear sensor on both front and the passenger rear brake callipers. It is a simple fuse-like device that breaks when the pad is worn causing the warning light. The mileage in the BC is just an estimate.
m3post
