04-17-2008, 10:34 AM | #1 |
137
Rep 536
Let's remove/install the Kidney Grills
Tools Required
T-30 Torx Driver Right Angle Tool Flashlight Flat Blade Screwdriver Removing the Kidney Grills With the hood open, begin by removing the 4 T-30 Screws above the kidney grills and set them aside. You will also want to lift the strip of insulation at the front of the hood off of it’s sleeve. You remove it by pulling up. The Kidney Grills are held in with 6 clips. There are three along the top edge, one along the side toward the light and two along the bottom. If you are replacing the Kidney Grills, look at the new Grills: you will see the locations of the clips. To remove the kidney grills, you need to lift the two clips along the bottom of the grills. The easiest way to do this is with a right angle tool. They are available from Sears and are a handy tool to have. Sears part number: 00999802000 ($12.99). Sears carries a few different varieties. You will want to begin by undocking the two lower clips. You will be able to see them in between the slats in the grill. You may need a flashlight to help you locate them. Once you have located them, insert the right angle tool to lift the center section of the clip and lift up. You will want to use your free hand to gently pull the grill toward you. You will want to prevent the grill from re-docking itself so once you have one side unclipped, keep enough pressure outward so it does not go back in. With the lower clips undocked, you can begin working on the upper clips. In order to access the clips, you want to pull up on the bumper trim and if you look in from the engine compartment, you will see the three clips. Use a flat blade screwdriver or the pointed end of the pick to push the clips down. As you did with the lower clips, gently pull the grill toward you to keep the clips from re-engaging. Once you have the 3 upper clips undocked, you can pull the grills out. Installing the new Kidney Grills To install the new grills, simply line them up and push them in until you hear the clips engage. Once you have both grills installed, replace the 4 T-30 Screws and tighten them down. Re-install the strip of insulation. If you follow this DIY , please post a thank you. Last edited by AndyM; 06-23-2016 at 02:41 PM.. |
04-20-2008, 01:08 PM | #3 |
325
Rep 1,804
Thanks for the DIY. I was wondering what "right-angled tools" everyone was using.
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
04-27-2008, 02:30 AM | #4 |
NRA Life Member, BMW CCA 30 year member
182
Rep 2,614
Thank you very much for this DIY. Today, I ordered a set of 128 nostrils/kidneys, I see the black grill bars as far more attractive on a black car than the stock 135 item which has chrome grill bars.
Resigned 1ADDICTS Moderator
To disarm the people is the best and most effective way to enslave them. George Mason |
04-27-2008, 03:19 AM | #5 |
182
Rep 2,614
The parts should arrive at the dealer late next week, weekend install, pics Saturday evening?
04-27-2008, 07:04 AM | #6 |
137
Rep 536
I did this on my Montego 135. The shadowline/tii grills were too black and the 135 grills were too chrome. I like the 128 grills quite a bit better than either.
04-27-2008, 07:59 AM | #7 |
Rep 293
I think the chrome grills look much better. The shadow grills almost look like nothing is there. IMO IMO IMO:wink:
2008 135i
Alpine White, Black'ette/High Gloss, Sport, CA, Heated Seats, iPod Adaptor, Premium hifi, Sirius, BMW Assist |
04-27-2008, 10:35 PM | #8 |
Only 1 n Rome
10
Rep 166
need a PIX really bad....dunno what i want unless I see sumpin pleeeeezzzz! Dark kidney's will look deadly on my car...but what shade of dark:iono:
Drives a Sawed-Off Shotgun
135i/SGM/Terra/Gray Poplar/Sport Pac/H&R Sport Springs & Sways/Heated Seats/Premium HI-FI/Sat |
04-27-2008, 11:14 PM | #9 | |
Rep 282
2008 (Year 1 of the One ) 135i Black Sapphire Metallic/Savanna Beige/ Gray Poplar/6MT/Sports & Premium pkgs/CA/Heated Seats/HD/PDC Mods:35% tint / clear bra / Perf. pedals |
04-27-2008, 11:36 PM | #10 |
182
Rep 2,614
128 kidneys have the chrome surround with black grill bars, as my 135 is JB, I thought the 128 kidneys would be more aesthetically pleasing, it plain looks better without chrome grill bars, at least, to me, plus, it's my car. Ha, ha...:biggrin:
04-29-2008, 02:21 PM | #11 |
137
Rep 536
Here is a comparison between the 3 available kidney grills.
128 Kidney Grills (Chrome with black vertical slats): 135 Kidney Grills (Chrome with chrome vertical slats): Shadowline/Tii Kidney Grills (Black with black vertical slats): |
04-29-2008, 02:50 PM | #12 |
182
Rep 2,614
Hey Andy, thanks for the presentation. 128 kidneys definitely for me.:wink:
04-29-2008, 02:53 PM | #13 |
137
Rep 536
04-29-2008, 03:01 PM | #14 | |
Rep 282
duh...guessing that is YOUR montego in the pics? if so...sorry for the dumb question haha
04-29-2008, 03:15 PM | #15 | |
137
Rep 536
I liked the shadowline grills when they were installed until I saw the car from across a parking lot. It looked like someone forgot to put them in. I thought the 135 grills were too much chrome for a car with no chrome on it so the 128 grills were the way to go. Tischer is probably your best bet for the 128 grills. The 128 and 135 grills are much cheaper than the shadowline ones. You pay for the white box with “BMW Performance” printed on it. |
04-29-2008, 03:17 PM | #16 |
Rep 145
Any one fancy selling their crome grills? as i prefer them with sedona, on my 123d i have the 128 grills.
123d M sport, Sedona Red, Boston Black Leather, 261s, Xenons, Bluetooth, USB, Brushed Aluminium, Darkened Glass, Cruise Control.
04-29-2008, 03:22 PM | #17 |
29
Rep 1,340
Drives: 2008 135i SGM MT
Garage List 1995 Acura Integra SE [0.00]
2008 BMW 135i [0.00] 2006 Porsche Cayman S [0.00] 1999 Toyota 4-Runner [0.00] |
Just playin around...I switched mine yestersday to the Shadowline perimeter with the OEM chrome tipped interior slats.
It presents a nice combination....not a completely "blacked-out" look and eliminates the big chrome frame.
2008 135i SGM |
04-29-2008, 06:18 PM | #18 |
Rep 282
yeah I might be willing to sell my chrome grills if and when I switch to another set...but I dont expect to take delivery of my 135i until July, so not sure if that is soon enough. Hope that helps, and thanks again Andy for the tip
p.s. Tischer?
04-30-2008, 09:33 PM | #19 |
BMF
Rep 84
Do you have a picture? This is the one combo I haven't seen.
135i
SGM, Coral Red Leather, Gray Poplar Trim, 6MT, Sport pkg, Premium pkg, Cold Wx pkg, Comfort Access, Premium Hi-Fi, Satellite Radio Delivered May 12th! |
05-01-2008, 05:54 AM | #20 |
29
Rep 1,340
Your wish is my command...........Shadowline frames with OEM interior grille bars.
2008 135i SGM |
05-01-2008, 03:26 PM | #22 |
Rep 255
Very cool! I got my shadowline grill at home with the car still on the way. I might have to take your idea and interchange the grills to look like that. Next you have to put the chrome lip and black grill. Change it up every month to mess with people:-P Its good to know you can switch the grills easily. Thanks AndyM for the DIY and TP 135i for the pics!
