ZPOST
  TireRack
      10-28-2008, 11:31 PM   #1
takedown8
takedown8's Avatar
56
1,068
Drives: 2005 BMW Z4 3.0i
How do you open the gear shift/selector panel?
Can someone please tell me how to open the plastic panel that surrounds the gear shifter? It's that panel in the centre that houses the gear selector, leather boot, and gear shifter.
Thanks!
      10-29-2008, 12:47 AM   #2
BimmerZealot
61
1,210
Drives: 2019 BMW X3 xDrive30i
I'm guessing automatic? If its the same as my old E46 auto. You need to grab the leather shift boot part and it will separate from the plastic, then with a very thin screw driver you should be able to get the plastic shifter surround out from the center console. Sorry I dont have specifics.
      10-29-2008, 10:44 PM   #3
takedown8
takedown8's Avatar
56
1,068
I tried it, and my leather boot doesn't separate at all from the plastic. Thanks though.
Anyone else?
      10-30-2008, 02:45 AM   #4
BimmerZealot
61
1,210
Doh, guess it's not the same. Sorry I couldn't be of more help. Hopefully someone that has done it before will chime in shortly. Its definitely removable as per RealOEM though, you might want to checkout the boot on RealOEM and see where all the tabs are to aid in removal.
      10-30-2008, 05:05 PM   #5
takedown8
takedown8's Avatar
56
1,068
It's this panel that I'm trying to open up:
      10-30-2008, 06:14 PM   #6
jra
38
879
Drives: 2005 z4
It has been awhile but the way I did it was to pull the e brake boot over the handle and then snap the the two plastic pieces in front of the e brake handle apart and then unclip the the gear selector surround.
This guy seemed to go take the shifter knob off and worked his way down http://www.motortribe.it/community/f...i-parte-17411/
zpost
