10-09-2008, 07:18 PM | #1 |
50
Rep 604
Help installing AFE filter...
Badfish posted this DIY, but I can't get the spring loaded black rod to hold the filter in place, it's too short, please help, I'm trying to do it right now
10-09-2008, 07:36 PM | #2 |
102
Rep 1,035
The little spring loaded rod should stick out similar to the picture below. If it doesn't stick out that far, it's stuck somehow. Mine was real strong and I can't imagine it getting stuck. Make sure that the hose and plastic adapter that plug into the filter (top portion of the picture) is correctly in place.
10-09-2008, 08:24 PM | #5 |
102
Rep 1,035
I would try to tap it loose first with a soft hammer. WD40 might end up attracting more dust and particles to make it stuck again later on.
See this thread for someone with the same problem.
10-09-2008, 09:19 PM | #6 |
50
Rep 604
I took apart the whole piece, but it seems that the Euro version has a shorter rod, I took it apart and it's not stuck, it's shorter, for some reason, Here's a pic, as you can see the round portion of the rod is the one that is smaller, not the base, what I did was cut the base on the OEM filter and glued it to the AFE one so it will hold it in place, but for some reason it's the Euro spec, as e mack from Australia and I get the Euro spec, that's all I can think about, weird.
