XBimmers X1   XBimmers X1
  XBimmers X1
      08-17-2019, 05:39 PM   #1
johnjh
Drives: bmw x1 2015 (e84)
How to detach two hoses onto engine cover
Does anyone know how to detach the two plastic rings holding the hoses crossing over the engine cover? (please check the attached picture)
I was trying pulling up the plastic rings hard several times, but I ended up stopping it because I felt they would be broke.
I am new to DIY things under the hood and this was the last step before removing engine cover. There's nothing mentioning about these hoses in DIY manual in newTIS.info though.
My car is E84 X1 s28i.
Thanks!
      08-21-2019, 02:11 AM   #2
johnjh
Which holder it may be?
I found a list of cable holders for my car as seen in the picture. I guess this is number 29 that has a screw at the bottom. Does anyone knows how to open it to release the hose? or do I need to remove the hoses from either end instead?
      02-12-2020, 09:19 AM   #3
blackhawks23
Drives: BMW X1 28i xDrive
So did you ever get it figured out? I ask b/c I have to do my spark plugs this weekend and I'm running into the same issue and can't find any description anywhere online.
xbimmers
