XBimmers X1   XBimmers X1
  XBimmers X1
      07-07-2016, 01:54 PM   #1
kiloTHREE
76
435
Drives: '13 xDrive28i
DIY: Cabin Filter
This is about the easiest thing you can do for maintenance so there is no reason not to do it yourself.
What you need.
8mm socket/nutset
Your hands
New filter (64 31 9 313 519) or similar, there are a few different brands to choose from
Open your hood and locate and remove 6, 8mm screws:
Different angle:
Now I'm sure you could just remove the top 4 and flop it over, but I wouldn't bet the bottom tabs will last long doing that.
Old vs new.
Remove the old filter, 3 plastic tabs hold it in on the bottom. Flip the filter out from the tab side.
Slide the new filter in top first, be sure it seats firmly against the corner tabs.
All set, now is a good time to clean up the cover and the tray under your car, I'm sure it's filthy. Mine was.
Put your 6 screws back in and bob's your uncle.
Be careful not to drop any screws, there are a lot of places those things can land under the cover that only satan himself will ever find again.
Between this guide and the set of instructions that may or may not come with your filter, there is no excuse not to do this yourself short of free maintenance work at the dealer.
      07-15-2016, 12:56 PM   #2
outlawdevil
46
Drives: X1 28i
although probably a bit late now, you could buy a roll of activated carbon sheet and tape it over the filter you know like the Tesla. lol. BTW great write ups. thanks.
      08-16-2016, 01:14 AM   #3
louisli
28
Drives: X1 2011 X25I
good job!
xbimmers
