04-02-2016, 11:27 AM | #1 |
265
Rep 570
Dashboard Trim Removal
I recently received a retro fit heads up screen for our buggy and was looking to install it.
http://f30.bimmerpost.com/forums/sho....php?t=1063158 The following need to be removed: Left dashboard cover 51 45 ... Bottom left and right dashboard trim 51 43 195 I found the left dashboard cover labeled as 10 in this diagram: https://www.partsbase.org/bmw/x1-e84...ent-panel-top/ At this point I am assuming that the bottom left and right dashboard trim are parts labeled as 1 and 3 in this diagram: https://www.partsbase.org/bmw/x1-e84...-panel-bottom/ What bugs me is that the numbers from install instructions do not match the part numbers in the diagram. Any thoughts? At the same time any else take their dash a part?? Any tips or tricks? |
04-05-2016, 07:09 PM | #3 |
265
Rep 570
THANKS for all of those. Is there one for:
Removing and installing/replacing instrument panel trim, bottom right. That would be trim "around" the glove box. I do not think I need to take the whole dash apart as with the trim removed I should be able to route the cable. |
