01-20-2016, 03:12 AM | #1 |
15
Rep 115
M5 failures?
Having done loads of searching it seems that the M5 is a pretty reliable motor!
I've had mine a few months and 2500 miles in, and keep looking at remaps by evolve and DMS, and have messaged litchfield with no response... But with a map there's always a worry that it's too much strain. Has there been any documented failures due to tweaking, I'd only ever go for a map with no bolt ons. As I've only done 2500 miles id want at least 5000 on it before considering one (I think ) Am I being a bit naive to think that even with a map it's still very reliable? As it is a relatively new engine and probably only been mapped in last 2-3 years |
01-20-2016, 04:22 AM | #2 |
101
Rep 483
From what I understand from those across the pond, the drivetrain, engine etc etc can take a fair amount of additional strain when adding more power....
My experience my my m5 has been pretty good, ive had a few niggles (nothing major) that have all been sorted out under warranty..but for me warranty is the most important thing when owning this kind of car and I know that any kind of modification would invalidate the warranty |
01-20-2016, 11:13 AM | #3 |
15
Rep 115
Yeah, warranty is a concern.
Asseemingly DMS offer a warranty with there map and it is pretty much untraceable anyway?! As its not a full re-flash it's basically manually coding in the lines that require it. So unless BMW go back and compare each line of code from 1000's they'd never know... Someone may come along and correct me |
01-20-2016, 11:44 AM | #4 |
5386
Rep 3,795
Any remap is detectable. There is no such thing as an undetectable remap. Its BMW's product at the end of the day. If they wanted to see if something had been changed they could easily do so.
With regards to reliability so far so good on this side of the pond and the US. We are currently running 750 BHP in my daily driven F10 M5 and have done many top speed runs and 60-130 MPH times. We have not had to replace any coil packs, spark plugs or injectors etc in this time. I think they are very robust. |
01-21-2016, 01:45 AM | #6 | |
15
Rep 115
I just find it hard to stomach £2k+ if it is an hours work on a reflash, but if it's a day or two of coding then it's understandable. Last car I had mapped was a TTRS + (not quite comparable I know) and was done by APR for around £650 and the change was worth every penny and more! But before we get off topic no-one has come back to say there has been a failure on this thread or another I have posted elsewhere so it's all very promising. |
01-21-2016, 08:09 AM | #7 |
5386
Rep 3,795
For ECU flashes/ECU Remaps data is extracted out of the ECU - some parts of the code are rewritten - new data is flashed back in. There is no secret way of doing this to make one companies remap less detectable than anothers.
FYI we do take the car in for 2 days at the moment to remap them. The car has 2 ECU's so its already double the work of any other F series BMW. If it was an OBD flash it would be less but there is no way to do this at present. You are more than welcome to come and check out our demo car. Its a bit more than a Stage 1 but will give you a good idea of what to expect. |
01-21-2016, 12:24 PM | #9 | |
5386
Rep 3,795
Just give us a call before hand so I can make sure the car is available. We are upgrading to bigger turbos around March time so it would be better for you to get an idea before then! |
01-21-2016, 02:38 PM | #10 | |
15
Rep 115
Wow that's quite exciting! What's the target... ? |
01-22-2016, 06:13 AM | #11 |
5386
Rep 3,795
