10-20-2015, 04:54 PM | #1 |
BimmerPost Supporting Vendor
2948
Rep 21,776
▀▄ eas | Dinan Suspension Complete Line Up - Authorized Dealer
Now available from EAS is Dinan's complete line up for the M4. As an authorized dealer we are ready to handle all your Dinan needs whether it be install or shipping. PM today for expert advice and info Dinan - High Performance Adjustable Coilover System - BMW F8X M3/M4 For the driver that demands the best out of their vehicle. The Dinan® Adjustable Coil-Over Suspension was bred in the race lab but refined on the street for maximum versatility. No matter the environment, the traction that is bestowed upon the vehicle from the improved suspension will inspire new found confidence when running at higher speeds. Combined with a substantial reduction in body roll as well as reducing dive under breaking and squat under acceleration. Dinan will guarantee you superior handling, performance, and comfort. Dinans design keeps the factory Electronic Damper Control shocks in place and implements threaded collars to allow the user to change the ride height. The end result is a sleek lowered stance that provides improved handling to go along with its stunning visual appearance. The springs combined with progressive bump stops and other components increase travel that allows the car to be lowered up to an 1” in the front and 1 1/2" in the rear. Suspension packers are included to fine tune handling and comfort by changing the clearance of the progressive bump-stops, something no respectable racecar is without. Components are machined from 6061-T6 aluminum and black anodized for appearance and corrosion protection. Features: - Threaded collars allow easy and precise front & rear vehicle height adjustments. - Included suspension packers allow adjustment of bump-stop clearance to fine-tune handling and comfort. - 100% compatible with EDC equipped models - Stock upper spring mounts are utilized for quiet operation - Substantial reduction in body roll. - Spring rates are nearly 50% stiffer in front and 10% stiffer in the rear. *Approximate Front/Rear Lowering: Front: Up to 1" lower Rear: Up to 1.5" lower * 1/2" drop is recommended in front and back to maintain a civilized ride. Models Supported: 2015+ BMW F8X M3 & M4 Dinan - Lightweight Adjustable Anti-Roll Bar Set - BMW F8X M3/M4 Almost all street cars come from the manufacturer with an anti-roll bar as it is a common part of modern suspension systems. However they are designed to be overly soft for maximum comfort. An anti-roll bar does exactly what it says by reducing body roll in all situations. Every Dinan® tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner. Front Anti-Roll Bar Add a 32mm Lightweight Tubular Adjustable Front Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time. This anti-roll bar is adjustable from 57% to 103% stiffer than the stock bar. This 4 hole bar can be mounted in 7 different positions with supplied adjustable end links. Features - Less Body Roll - More Mechanical Grip - More Stable At Limit - Large 32mm size (stock bar is 24.7mm) - 4 hole bar with 7 possible positions on the bar w/ supplied adjustable end links. - Tubular (Hollow) Construction Models Supported 2015+ BMW F8X M3/M4 Dinan - Rear Suspension Link Kit - BMW F8X M3/M4 Dinan’s High Performance Rear Suspension Link Kit adds precision and predictability at the limit. The stock rear toe link is built with rubber bushings and a curved forged alloy rod which can easily flex. During hard acceleration this flex allows the rear wheels to have excessive toe change under hard acceleration and braking. All of this flex in the stock toe link causes the car to be unstable. Dinan® stops the flex by replacing the rubber bushings with Teflon coated machined steel rod ends and the OEM curved bar with a straight billet aluminum rod, thus adding stability. The Dinan rod-ends incorporate left and right hand thread, which allows quick and accurate toe adjustment that is tough to achieve using the stock system. Like the rear toe links, the stock front trailing links also incorporate rubber bushings. Flex in these bushings allow the rear wheels to behave sloppily under heavy loads. Dinan adds precision by replacing these links with billet aluminum rods and Teflon coated machined steel rod ends. These front links are not adjustable, because there is no need to doing so. Features - Replaces the stock rear toe link & rubber bushings with a precision machine black-anodized aluminum tube and racing-quality rod ends. - Replaces the stock forward lower trailing link & rubber bushings with a precision machine black-anodized aluminum tube and racing-quality rod ends.. - Dramatically improves vehicle stability during hard cornering. - Improves response by eliminating the deflection of the rubber bushings. - Rod-ends are Teflon-lines for quiet operation. - Rod-ends incorporate left and right hand thread, which allows quick and accurate toe adjustment by simply turning the aluminum tube. This eliminates the need to struggle with the factory eccentric adjustment. - Only rear toe links are adjustable. Trailing links are not adjustable. - Rubber boots protect rod ends from environmental damage for long lasting performance and removes the need for constant cleaning. Models Supported 2015+ F8X M3/M4 Ordering: Phone: You can reach us directly by calling 866.669.0705 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday - 9AM-2PM PST Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell. Contact Info: Phone: 866.669.0705 x31 Email: kevin@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact me via PM, email, or phone if you have any questions.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 11-05-2019 at 12:37 PM.. |
10-22-2015, 03:09 PM | #2 |
2948
Rep 21,776
Lowered with Dinan Adjustable coil overs
Pm today for pricing and info on Dinan Courtesy of Greg FEightytwo
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
10-28-2015, 02:06 PM | #3 |
2948
Rep 21,776
Get your Dinan F8x M3/M4 suspension from EAS today!!
PM for pricing and details
11-03-2015, 05:43 PM | #4 |
2948
Rep 21,776
Lowered using Dinan sleeve over kit
PM today for pricing and details
11-05-2015, 02:19 PM | #5 |
2948
Rep 21,776
Thanks for the inquiries
We are an Authorized Dinan retailer PM today for all your Dinan parts
11-10-2015, 02:42 PM | #6 |
2948
Rep 21,776
Dinan sway bar set available for you F8x M3/M4
11-17-2015, 11:24 AM | #7 |
2948
Rep 21,776
Get your Dinan suspension from EAS today!
11-20-2015, 11:13 AM | #8 |
2948
Rep 21,776
Dinan sway bars just installed
11-24-2015, 04:15 PM | #9 |
2948
Rep 21,776
Dinan adjustable sway bars ready to ship
12-01-2015, 01:02 PM | #10 |
2948
Rep 21,776
12-09-2015, 02:41 PM | #11 |
2948
Rep 21,776
Dinan Sway bars ready to ship
12-18-2015, 01:42 PM | #12 |
2948
Rep 21,776
Dinan suspension kits ready to ship
01-13-2016, 11:04 AM | #13 |
2948
Rep 21,776
Dinan rear suspension link kits ready to ship
02-01-2016, 07:05 PM | #14 |
512
Rep 709
02-02-2016, 11:29 AM | #15 |
2948
Rep 21,776
I would say right about a 1/2 drop all around. That car has no spacers either.
02-10-2016, 11:34 AM | #16 |
2948
Rep 21,776
Dinan Tension strut ball joint kit available
PM today for Dinan inventory and pricing
03-10-2016, 05:52 PM | #17 |
2948
Rep 21,776
Get your Dinan suspension from EAS PM today for pricing and details
03-18-2016, 05:55 PM | #18 |
2948
Rep 21,776
Get your Dinan suspension from EAS!! PM today for pricing and details
04-06-2016, 04:56 PM | #19 |
2948
Rep 21,776
Dinan adjustable toe arms
PM today for all your Dinan suspension needs
06-03-2016, 05:28 PM | #20 |
2948
Rep 21,776
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 06-03-2016 at 05:39 PM.. |
06-16-2016, 12:10 PM | #21 |
2948
Rep 21,776
Diann adjustable coil over system
PM today for details and pricing
06-23-2016, 11:42 AM | #22 |
2948
Rep 21,776
NEW lower price on Dinan Adjustable coil over systems
In stock and ready to ship PM today for details and pricing
