New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Regional Forums > USA - Southeast
      09-02-2015, 05:10 PM   #1
Sean@PSI
Sean@PSI's Avatar
2153
5,011
Drives: 2021 IOMG M3 Sedan
We are Central Florida's #1 BMW Service and Repair Shop!
Precision Sport Industries is a BMW specialist shop with a 5,000 square foot facility located in Winter Park, Florida. Here at PSI, we define ourselves by our level of service, maintenance experience, and our ability to fulfill the dreams of every enthusiast that brings their treasured BMW to our facility. We pride ourselves in transforming your ideas into reality, using only the very best parts available and the highest level of skill possible. Regardless of the purpose of your visit to PSI, whether tiny or immense, we are committed to your complete satisfaction. We simply wouldn't have it any other way, and we feel you should not either.
Our service and diagnostic team has decades of expertise, so it goes without saying that you are in good hands here. In fact, the extensive experience on staff makes us the first choice for any type of work, no matter how complex. Anything from a simple oil change to an intensive street, show, or racing build is just another day in the shop for us. As you can see from some of our previous projects, our commitment to quality and excellence takes priority over any type of margin.
We feature the latest BMW Diagnostic technology including a BMW GT1, Auto Logic and INPA. With these specialized state-of-the-art tools, we can find the root of a problem faster than any shop in the area. We specialize in OEM replacement parts as well, and we guarantee the exact OEM replacement part to keep your BMW showroom new. From E30 to F30 and beyond, we can help you keep your BMW in top shape with access to the best parts, from the world's leading manufacturers.
With our combined experience of over 30+ years of BMW Repair and Service, we are the #1 choice in Central Florida for dealer alternative BMW Service.
Our service department features these OEM brands:
Contact us with any questions, or feel free to stop in and see us any time during normal business hours!
828 Cherry St.
Winter Park, FL 32789
407.617.0372
Email Us
Visit Our Website
      09-14-2015, 07:24 PM   #2
Sean@PSI
Sean@PSI's Avatar
2153
5,011
N54 Valve Cleaning : The Inside Story of the Walnut Blasting Technique and Process
For everyone who is interested in what actually goes on during a special intake valve cleaning, here is some more information along with several other detailed photos of the process. Without further ado: the story behind it all.
When BMW introduced the N54B30 powerplant to the United States market in 2007, it was their first production turbocharged engine that utilized direct injection technology. This means that instead of traditional intake manifold fuel injection, the engines injectors are placed literally inside the combustion chamber, next to the spark plug. Direct injection boasts better fuel economy, and has proven to be a revolutionary development for the internal combustion engine. The technology is now found in nearly every new production car!
While pioneering the market with the N54B30, BMW did have their share of growing pains with this new technology. There were several revisions for the high pressure fuel pump, and many other sensors and electronics pertaining to the fuel system had their issues as well. One of the major oversights with this technology development was the intake port and valve carbon buildup.
The N54B30 has a crankcase ventilation system that is internally routed in the cylinder head. If you look down into the intake port, you’ll notice a hole on the top of the port that is used by the CCV for vacuum. The problem now is that oil that makes its way through the CCV will end up in the intake port of the cylinder head - which wouldn’t be an issue if there was an injector in each port cleaning it with fuel. Since the N54 doesn’t have any fuel injectors in the manifold, the oil residue builds up on the intake port and intake valves over time. Newer cars such as the Scion FR-S that are direct injected have a second set of injectors in the manifold to help prevent the issue of buildup that the N54 has.
Fortunately BMW recognized the issue and at the very least they have provided us with a genuine BMW tool that can be used to “blast” the carbon buildup off the port and valves.
When the cleaning of the intake valves became regular maintenance on the N54 engines, we experimented with various ways to properly and effectively clean the carbon buildup. We tried chemical cleaning, simple walnut blasting, scrubbing, etc.. After years of dealing with this issue we’ve come up with what we feel is the most effective and efficient way to get rid of the carbon.
Remove the intake manifold.
Inspect the intake port.
Rotate the engine so that the valves are closed in the port being worked on, and then fill the port with a carbon solvent.
Once the solvent has had time to penetrate the buildup, we use a variety of picks and brushes to loosen the carbon buildup, and then using the OEM BMW tool, we walnut blast the port until it is clean.
Inspect, and then clean all missed areas.
All clean!
Feel free to contact us with any questions, or to schedule a service!
      10-28-2015, 09:06 PM   #3
Sean@PSI
Sean@PSI's Avatar
2153
5,011
Call now to get on our November schedule!
Tags
bmw, precision sport, psi, repair, service
zpost
