07-18-2015, 11:34 AM | #1 |
819
Rep 7,887
Broke my M4 this am!
While bedding in brakes & heat cycling tires 1st session my transmission decided to stop delivering power in the odd numbered gears and there is a loud thumping noise while it is trying to deliver power in those gears.The strange thing is there are no notifications alerting to a problem.I was only puttering waiting for the temps to come up.I drove the car to the dealer which was about 80kms away using the even numbered gears.Everything points to the No1 clutch going
07-18-2015, 11:38 AM | #2 |
1905
Rep 5,678
That is really unfortunate. The DCT has proven to be pretty tough so I'm interested in the outcome. Hope it is fixed soon!
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
07-18-2015, 12:21 PM | #3 |
819
Rep 7,887
I missed two days this weekend which were going to be setup days and co driver familiarization for the Ontario 1500 which we are running in September.I think the key thing is having two cars that can be tracked.My dealer was suggesting an M2 for my wife to solve this
Issue! |
07-18-2015, 03:54 PM | #4 |
21132
Rep 20,742
Drives: 2021 911 turbo
Ouch
I wonder if there is any relationship with your brake issues . Keep us posted.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
07-18-2015, 04:46 PM | #6 | |
819
Rep 7,887
I do think it is a mechanical issue as there no warnings or anything in the memory.At least my service advisor has a M Coupe has been to the track with myself at one of the dealership track days. |
07-20-2015, 01:04 PM | #8 |
819
Rep 7,887
07-20-2015, 01:07 PM | #9 |
91
Rep 299
Drives: m3 2015
So may be the loud thumping noise is a new way by BMW to let you know something went boom. You know the Germans only do things the correct way.
07-20-2015, 03:02 PM | #10 |
BimmerPost Supporting Vendor
9604
Rep 10,891
I'm certain BMW will address the issue for you under warranty. I'm interested to see what the problem was! As mentioned above, the DCT transmissions are stout- my hope is that this failure was an outlier.
07-20-2015, 03:24 PM | #11 |
819
Rep 7,887
The dealer e mailed me that they are doing a program update 1st as per BMW and they will see what happens once this is done.They feel it is a mechanical issue also.
07-20-2015, 03:29 PM | #12 |
9604
Rep 10,891
Interesting! From what I've seen, BMW's warranty process (as it relates to transmissions) skips through a few simpler steps like the one you just mentioned, and typically lands at "let's replace the whole transmission". I'm hoping for the best result for you.
07-20-2015, 03:41 PM | #14 |
819
Rep 7,887
07-21-2015, 05:59 AM | #15 |
1162
Rep 1,726
broke mine too..
Rear Differential Lock Error... either the GHAS unit is toast or the entire diff. i feel like it's an overheat issue.
My Trackable Street Car
2016 BMW M4 GTS |
07-21-2015, 12:08 PM | #16 |
819
Rep 7,887
They did the programming update and no change in the problem as we expected. Waiting for BMW to make the call of what to do next!It is a Puma case according to the dealer.
07-22-2015, 10:45 AM | #17 | |
9604
Rep 10,891
As you stated, it must be a hardware issue at this point! I'm hoping for a swift resolution for you.
07-22-2015, 12:56 PM | #18 | ||
819
Rep 7,887
07-22-2015, 01:32 PM | #19 | |
3189
Rep 10,509
that IS being pretty conservative |
07-22-2015, 01:40 PM | #20 |
819
Rep 7,887
07-22-2015, 11:51 PM | #21 |
69
Rep 96
mine had a similar behavior but i got the 'driveline malfunction' error and the DCT was skipping the even or odd (cant remember) gears. i turned the car off, the error code went away, and everything is fine.
but every now and then, randomly, i'll get that driveline malfunction error on the screen and the car will either do the gear skipping, or not shift at all, like stay in 1st gear and i cant shift out. but every single time, i can shut the car down and immediately turn back on (reboot) the codes go away and the thing drives perfectly fine. i've tracked it pretty hard on 2 occasions and it held up to the punishment well. first time tracking the car threw that error, 2nd time tracking no errors. |
07-23-2015, 03:04 PM | #22 |
819
Rep 7,887
So the good news!BMW has authorized the replacement of the transmission but it will be 2 weeks before it will arrive from Germany.I have asked them if it can be airfreighted. I am pretty sick of driving the 320 XI everyday My dealer has been great through all this!
