06-14-2015, 07:36 PM | #1 |
Hide! My wife's coming!
814
Rep 2,816
OEM F10 Exhaust Valve Mod
Finally got around to doing this since I picked up my M5. It definitely improves the exhaust note at startup and cruising around. Will keep me satisfied until I get an exhaust system.
What I used Flathead screwdriver Band Clamps 1-13/16 to 2-3/4 Stainless Steel While turned off, I wrapped the band clams around the actuator arm and its mount and started turning the screw. Once it the screw becomes harder to turn, I pushed the valve arm in to full open and screwed the clamp further until it was secured. Here are the pictures. I'll post a video later. |
07-08-2015, 05:38 PM | #3 |
10
Rep 84
+1
Did this shortly after picking mine up after reading about it. Honestly, quite surprised how much better it sounded. Cold start grins guaranteed!
2013 M5 BSM/SS - BMS Stage 1, Turner Race Exhaust, 12mm spacers, KW HAS, Dinan sway bars, IND cosmetic package, LED kit, V12 coded
07-14-2015, 09:59 AM | #4 |
814
Rep 2,816
Just realized I never posted the pictures.. I ended up getting the Turner Muffler Delete so never got to get a video but here are some pictures. If you look at the solenoids, you will see that I have the band clamp around the actuator/arm.
07-14-2015, 05:08 PM | #5 | |
10
Rep 84
Do you find it much better/louder than stock with valve mod? Tone difference as well as volume? Been considering this also as an upgrade to running stock cans with open valves. Let's hear it! |
07-14-2015, 07:30 PM | #6 |
814
Rep 2,816
I love it and it's ALOT louder outside than the stock exhaust. Inside the cabin it's not much louder than stock.
i PM'd you some videos. |
09-20-2015, 05:15 AM | #7 |
19
Rep 70
Where does the vacuum solenoid seats?
Is there no way to cut dme signal and take an ignition plus with a switch to open and close valve manually?
09-20-2015, 09:21 AM | #8 | |
814
Rep 2,816
JB4 from BMS http://www.exhaustmeister.com/ I am not sure about your DME question as I do not have that experience but might be worth asking in tuning page. I tucked the hose in the bumper above the muffler. The hose runs to the solenoid that is located in the trunk behind the carpeting. This is what I was told but I've never confirmed.
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
10-16-2015, 06:25 AM | #10 | |
814
Rep 2,816
10-16-2015, 10:18 PM | #11 | |
20
Rep 102
Drives: RRS Supercharged / 991 Turbo S
Cheers Craig.
2015 White 991 Turbo S - Warp Factor 9!
2016 Yulong White Range Rover Sport 'Stealth Pack' 2015 Alpine White M5 'Competition Pack' - Gone 1971 Mercedes-Benz 280SE - Just love looking at it! 2012 Alpine White M5 - Gone |
