Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      03-23-2015, 11:07 AM   #1
M3NetNerd
20
124
Drives: 2015 BMW M3
Tires for Apex 18X10 ET 25
Now that the GB is over for the Apex EC-7's I am debating what size tire to put on the rims.
Do I go square with 275's all around?
What would be the largest rear tire I could fit on those rims?
I am thinking about getting set of the new RS3's due out at the end of April.
      03-23-2015, 11:29 AM   #2
hellrotm
4143
6,926
Drives: F80
This M3 is running same setup with 275/35/18 Toyo RA1 all around.
      03-23-2015, 01:18 PM   #3
M3NetNerd
20
124
Drives: 2015 BMW M3
Thanks!
      03-26-2015, 07:04 PM   #4
evanescent03
evanescent03's Avatar
1033
1,997
Drives: '24 M3 CS; '22 GT4
i dunno about the widest, but i just ordered a set of 275/35/18 nitto nt01 for mine..unfortunately i just missed out on the group by by a few days i literally started shopping the day after it ended ...
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
      04-05-2015, 09:13 AM   #5
M3NetNerd
20
124
Drives: 2015 BMW M3
Does anyone know if 285's will fit in the front using these rims? Thinking about a 285 square setup.
      04-08-2015, 07:27 PM   #6
chili cheese
chili cheese's Avatar
101
1,086
Drives: '16 Corvette Z06
Here's what I've got:
275/35/18 NT01 on ARC-8 for track
275/35/18 PSS on EC-7 for street
      04-08-2015, 08:32 PM   #7
evanescent03
1033
1,997
what are your wheel specs? any spacers? thanks!
      04-08-2015, 10:43 PM   #8
JNoSol
JNoSol's Avatar
1386
3,834
Drives: 750 MSPORT & E90M3
The E9x offset are different than ours. Also, I don't think the ARC-8 can clear our brakes. I could be wrong on the ARC-8.
Daily: G12 750 MSPORT Weekend Car: E90 M3
      04-08-2015, 10:45 PM   #9
JNoSol
JNoSol's Avatar
1386
3,834
ET33 + 10-12mm spacers front + 285/35/18 "should" work. It also depend on tires brand and type, most slicks (like Hoosier) are wider than the size shown. You'll have to dial the spacers just right, especially if you're using K&W CS (they cut way about 8-12mm of room). I know for sure the E9x guys can run 285 with slight rubbing on the plastic shroud.
If I were you, I would go to the local tire shop and get test fitted before buying the tires.
      04-09-2015, 12:12 AM   #10
evanescent03
1033
1,997
I was wondering about that -- didn't realize he was in an e9x car (on my phone i can't see sigs or the info on the left). I know I had heard the arc-8 doesn't work so thought that was getting de-bunked... guess not! thanks for pointing that out.
      04-10-2015, 07:06 PM   #11
chili cheese
101
1,086
Correct fellas. I assumed the thread intent was just what rubber was being used on that particular wheel. My offsets, spacers, suspension (I'm on clubsport) will all be different. Good luck!
      04-12-2015, 11:47 AM   #12
M3NetNerd
20
124
Drives: 2015 BMW M3
I was looking for info specific to the F80.
I am going to start with a 275/35/18 square setup. I can confirm the Arc-8's will not work with the F80. I got an email stating that from the manufacturer.
      04-13-2015, 08:38 AM   #13
M3NetNerd
20
124
Drives: 2015 BMW M3
For the sake of others who may be in my situation. I just pulled the trigger on these.
http://www.tirerack.com/tires/tires....Potenza+RE-71R
f80post
