03-02-2015, 07:50 AM | #1 |
One mod leads to another ...
419
Rep 2,900
Track/Street Camber Settings
I think I am going to ditch my KW HAS springs and go with KW Clubsports like I had on my E90 M3. I'm interested in what front camber settings you guys are running? I'd like something I can run on the street and track; a balance between both without destroying my tires either place. I think I ran -2.0 on the E90 but I've read that the F80/F82 might be like the E46 and need even more negative camber for even tire wear on the track. With that being said, I think -2 would still be likely a good place to start.
Current: 2014 F10 M5 Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3 |
03-05-2015, 09:46 AM | #3 |
419
Rep 2,900
No I didn't track it yet.
03-24-2015, 11:35 AM | #4 |
1386
Rep 3,834
If you haven't bought it yet, consider TCKline. It's less the price of the K&W Clubsport / same performance / same quality / same warranty. The cool thing is, TC (owner) has an M4. He can share this street/track settings that he has dialed in. Also, with TCKline you can swap out spring rates if you're not happy. Double Adjustable (recommended for track and street) is $3,103/set which also include camber plates.
http://www.tcklineracing.com/ |
03-24-2015, 08:38 PM | #5 | |
707
Rep 886
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
