Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      10-11-2014, 05:35 PM   #1
M!
26
38
Drives: 2015 M4
M4 Battery Charging Via 12V Accessory Port?
I only use my M4 for weekend fun drives and the rest of the time it rests out of the elements in my garage. (My daily driver in the local Los Angeles traffic is a Sienna minivan.) I just bought a Ctek lithium battery charger to keep it topped and want to connect it in the simplest, easiest fashion without having to lift the hood each time I use it.
Does anyone know if I can use the cigarette lighter/accessory plug for this purpose?
Thanks.
      10-23-2014, 08:44 PM   #2
flyboy_vu
flyboy_vu's Avatar
16
Drives: 2015 BMW M4
I was thinking of the same thing about getting the CTEK LITHIUM US for my M4 since it will be garaged for 3 months. I called my local BMW service department and they told me that you could use the cigarette lighter/accessory plug for this purpose with the trickle charger they sold. I asked them if they had any Li Ion trickle charger and they told me they didn't even know that the M4 had a Li Ion battery, so I became weary of their recommendations.
I'm assuming that you bought this:
http://smartercharger.com/products/b...ek-lithium-us/
Does the CTEK lithium battery charger you purchased came with a cigarette lighter/accessory plug?
      10-23-2014, 08:55 PM   #3
GlobalScientist
86
278
Drives: M4 Vert
I have a solar one I use for another car, but have to see if I can use it for the bimmer.
      10-24-2014, 04:45 AM   #4
fun2drv
fun2drv's Avatar
262
561
Drives: '23 M5 Comp
2023 BMW M5  [10.00]
2023 BMW M5  [0.00]
No, the newer BMWs do not have an active cigarette lighter/accessory receptacle when they are shut off. You need to connect it directly to the battery in the right side of the trunk.
I have the charger here, just waiting for my car that is on a boat right now...
Best of luck!
      10-24-2014, 04:59 PM   #5
M!
26
38
Drives: 2015 M4
Yes, I bought the same charger that your link shows. However, I got it new on ebay for under $90, including shipping. It did not come with an accessory plug.
      10-25-2014, 11:49 AM   #6
Boss330
Boss330's Avatar
1722
5,110
Drives: BMW
Best of luck!
Most (all?) modern BMW's have charge points under the bonnet since the battery is difficult to access.
      10-25-2014, 12:01 PM   #7
jewels
30
217
Drives: 2017 X3 & 2015 M4 Vert
You can wire the charge points to have a pig tail so it sticks out of an area such as just behind the grill.
Not a hard thing to due even for the mechanically challenged, just make sure the exposed end (plug in) has some type of cap when not in use.
BMW Owner 2-3 & 4 Wheels
      10-26-2014, 02:53 AM   #8
flyboy_vu
flyboy_vu's Avatar
16
Drives: 2015 BMW M4
Best of luck!
I'm not so sure you'd want to directly connect it to the battery in the trunk since most BMW vehicles have an "Intelligent Battery Sensor" to prevent damage to the battery.
Did some digging and I may go this route through the hood of the car to the windscreen.
I'm not sure if the M4 has charging capability though the cigarette outlet which could be from inside the car or from talking to CTEK, an outlet in the trunk. Can someone confirm?
In any case, CTEK does offer a cigarette outlet option for other chargers, not sure if it will work for the M4.
http://smartercharger.com/products/a...nect-cig-plug/
I wish BMW manuals has more amplifying data on storing our vehicles.
2015 Mineral White M4 DCT
      10-26-2014, 08:15 AM   #9
jewels
30
217
You cannot charge a M3-4 through the lighter...but I do believe there are charge points under the hood just like our 435.
      10-26-2014, 08:24 AM   #10
mkoesel
Moderator
7525
19,368
Drives: No BMW for now
The manual warns against charging from the accessory sockets. This may or may not be standard boilerplate liability coverage, but I would be reluctant to go against it without some reasonable assurance it can be safely ignored.
      10-26-2014, 09:24 AM   #11
fun2drv
fun2drv's Avatar
262
561
Drives: '23 M5 Comp
2023 BMW M5  [10.00]
2023 BMW M5  [0.00]
Has anyone tried to see if the alligator clips actually reach to both the (+) and (-) terminals under the hood? I have the CTEK charger, but my car is still on a boat coming to the US form my ED. I'm not sure that there is enough wire length on the alligator clip attachment to reach both terminals...
Thanks!
BTW - Once and for all, you CAN'T use the accessory plugs inside the car. There is no power when the car is shut down... People keep asking the same question here...
      12-08-2014, 03:53 PM   #12
Wregie
United Kingdom
46
Drives: Mineral White. DCT M4, S1000RR
OK so I tend to "Cabin Up" my car during the winter months, when salt is on the road, and plug my Optimate 6 to the battery to keep it topped up and ready. I hadn't realised the M4 had a Lion battery until I went to connect my Optimate 6. So I am correct in assuming I cannot use the Optimate 6 and, if not can I use this?http://www.optimate.co.uk/optimate%20lithium.htm
      12-08-2014, 03:55 PM   #13
Wregie
United Kingdom
46
Oh, and from what I have read it must be connected to the charging point under the bonnet (Hood) and not directly to the battery.
      10-09-2015, 08:37 AM   #14
Zerouali
Zerouali's Avatar
66
191
Drives: BMW M3
Yep, just picked mine up(the charger) and it says for batteries installed in a car connect the red to the battery pole and the black to the chassis away from battery and fuel pipe(assumes negatively earthed battery) so the under bonnet(hood) connections look like the only way.
      10-09-2015, 10:44 AM   #15
dmnc02
dmnc02's Avatar
920
1,481
Drives: 2015 M4
If you are asking about the clips that come with the CTEK charger, they reach.
2015 Mineral Grey ///M4 6MT
      10-09-2015, 10:50 AM   #16
Mandi90TT
2712
2,371
Drives: BSM 6MT M4 F82
There are charge points under the hood. I've got the same CTEK charger, and I hardwired the pigtail to the charge points under the hood, with a fuse, even.
2015 Black Sapphire Metallic 6MT M4
      11-15-2015, 08:08 PM   #17
sh55
sh55's Avatar
221
433
Drives: %E2%80%9805 E46 ZCP 6MT and '9
How did you hardwire the CTEK pigtail? Specifically how did you do it for the larger positive terminal?
I just hooked mine up with the clips but would prefer to have the pigtail on there permanently for the convenience.
______________________________
?05 E46 M3 ZCP 6MT
?06 C55 AMG
'97 911S 6MT
      11-15-2015, 08:27 PM   #18
MasterP
722
2,342
Drives: All the M's
Most Ctek kits come with M6 terminals, you need the M8 terminals for the F8X.
http://www.amazon.com/CTEK-56-261-Co...ZM5VC66NH82NAK
Red goes to the Red Post, Black to the Metal post. Done.
      11-15-2015, 08:29 PM   #19
MasterP
722
2,342
Drives: All the M's
you CAN use this too:
http://www.amazon.com/Cigarette-Adap...ctek+cigarette
This is pretty much what comes with the Mclaren Li-On Charger and I've used it in my F80.
      11-15-2015, 09:14 PM   #20
sh55
sh55's Avatar
221
433
Thanks, so the Red post has a bolt on it or a way to unscrew it to attach the pigtail (sorry, I didn't see a way to do it but I'm new to BMW charging terminals)
I don't think the F8X supports charging through the accessory port per other posts, but either way I'd rather charge under the hood
?05 E46 M3 ZCP 6MT
?06 C55 AMG
'97 911S 6MT
f80post
