07-01-2014, 03:13 PM | #1 |
1030
Rep 1,191
Racer20's Adaptive Suspension Review
(Maybe the wrong forum. Mods can move it if they wish)
To sum it up, it's good. Really good. It's better than the E9X, better than the F10 M5. If you didn't order it, you're missing out IMHO. I need to refuel after a long drive (beer and a burger), but I'll be back in a couple hours with a proper review. _________________________ I'm back. First, I want to clear up some misconceptions . . . the point of adaptive suspension is NOT to make the car more comfortable, it IS to reduce unwanted body motion and keep the car as flat as possible under all conditions of driver input and road condition. The adjustments that are made every couple milliseconds are targeted towards keeping the tire in contact with the ground and keeping the body flat. The challenge for passive dampers is that having enough damping to keep the body as flat as you'd want it often results in over-damping of the wheel, which means it will loose traction on a bumpy surface and ride poorly. Adaptive dampers work by providing much closer to the ideal damping rate for all conditions. An good adaptive damper can be more comfortable and compliant than a passive damper AND have better body and wheel control at the same time. My benchmarks for adaptive damper performance (besides some prototype cars that I've tuned myself) are the E92M, Cadillac ATS 3.6 with MR, and the F10 M5. I consider these cars to be well tuned, but each has its faults that I'll get into later. With that in mind, I can say that the F80 has the best adaptive suspension I've ever driven. It's pretty much how I would envision tuning the perfect car for myself, understanding the physical limitations of such a system. To break it down further: Comfort Mode This is where a lot of systems fall down IMO. Usually the middle mode is pretty good, but the comfort and sport modes are tuned as afterthoughts, and they are exaggerated on purpose just to be different from normal. The M5 is like this to some extent. Comfort mode is comfortable, but its floaty and the steering feels disconnected no matter what steering mode its in. The F80 on the other hand has no exaggerated float in comfort mode and the steering is still direct and precise. Road imperfections are felt, but they are very well damped and never intrusive. Body motions are a LITTLE BIT larger, but never jerky, bouncy, or floaty. Overall, the car is very smooth and calm, with little to no head toss or pitch. To me, it feels like what a well tuned 335i M-Sport should be. Sport Mode The car defaults to this when you start it up. If I'm on the expressway, I can actually feel the car firm up in sport mode. It breathes just a bit less and has more support in compression, especially in the rear. Any hint of extra movement in the rear is gone, but road texture isolation is still good, and impacts are still well damped. I didn't actually spend much time in sport, instead switching between comfort and sport+. The E92M and most MR cars seem to transmit a lot of road texture and small inputs due to either high friction or lack of compression damping range. This car seems to have enough range to deal with anything you can throw at it. I didn't encounter any crashiness in any mode today, but that's typically not an issue on the roads in Germany anyway. If I find a different story back home on Michigans moon surface roads, I'll edit my post. Sport + I dialed the car up to sport plus whenever I hit a twisty section. It's firm, but not overly firm. Small road inputs are still well damped, but the extra body control starts to tug at the rear of the car over uneven pavement. One of the narrowest, twistiest sections today also happened to have the worst roads. Not broken or cracked, but lots of patches and heaves that tossed the car around quite a bit. In sport +, the body and wheels were very well controlled. Combined with the precise steering and good kinematics (bump steer/roll steer, etc), I was shocked at how well the car tracked around these difficult corners. Body roll As the chassis engineer states in the interview that was posted today, comfort, sport, and sport plus all have about the same stiffness when you intially turn into a corner. Typically, when you first turn the wheel to enter a corner, the dampers will spike the compression or rebound quite high to immediately counteract the body roll. BMW did a great job getting this right, as body roll is balanced and well controlled in every mode. When sport + is selected for both steering and damping, the result is a car that turns in quickly with minimal body roll, and feels very linear and predictable. When they say anyone can get in this car and go fast, they are right. It's very intuitive. Steering Does the wheel communicate every pebble on the road through the wheel? No. But this isn't a lotus Exige. There is a bit of road texture that makes its way through, and as everyone else has stated, it's very accurate and the weight is good. I never found myself needing to correct, whether mid corner or at 90mph on the autobahn. I didn't push the front tires past their limit, so I'm not sure how well it will communicate that, but so far I have no complaints whatsoever about the steering. It works in concert with the dampers to provide a great driving experience. Overall, I'm extremely impressed with this car. It feels light on its feet, smooth, and effortless, and the suspension, steering, transmission, and engine all work together to disappear behind the scenes when you're attacking a challenging road. To those on the fence, there's really no question in my mind that the adaptive dampers are a must have. The passive dampers are probably phenomenal, but it's not physically possible for them to be as good as the M adaptive at all these things. I doubt the BMW chassis dynamics engineers are reading this, but if they are, I tip my hat to them. This is the best car I've ever driven. I really want to get a set of these off a car and put them on the dyno.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
07-01-2014, 03:31 PM | #3 | |
1030
Rep 1,191
07-01-2014, 04:42 PM | #5 |
593
Rep 5,396
07-01-2014, 05:12 PM | #6 | |
1030
Rep 1,191
I have not tested the passive suspension, but if someone near SE Michigan would like to meet up to try out each others cars, I will post a review.
07-01-2014, 05:24 PM | #7 | |
Resident Engineer
135
Rep 748
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD 2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air European Delivery Journal & F8X Door Rattle Fix Machine Shop Directory - www.mfgcenter.com |
07-01-2014, 05:45 PM | #8 |
M3AT LOVER
322
Rep 1,853
Excellent review! I added this is now included in our FAQ sticky thread. Thanks.
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
07-01-2014, 07:51 PM | #10 |
6833
Rep 6,803
I'd love to hear more of your thoughts on the chassis deep dive in this thread, especially in light of your review today.
http://f80.bimmerpost.com/forums/sho....php?t=1005164 |
07-01-2014, 08:01 PM | #11 |
21131
Rep 20,742
Drives: 2021 911 turbo
Excellent review I really appreciate knowledgeable folks sharing their perspective |
07-01-2014, 08:28 PM | #13 |
992
Rep 1,370
Glad to see someone who has hands-on experience with chassis engineering giving positive reviews of the F8X
i'll be sure to tick this box when ordering next year.. thanks for your input! |
07-01-2014, 08:41 PM | #14 |
1589
Rep 2,148
You inspired me to add it per previous posts. After reading this, I'm glad I did. I just wonder how badly I'm going to ruin superb tuning by lowering the car slightly?
07-01-2014, 08:50 PM | #15 | |
1030
Rep 1,191
Regarding the sensors, many OEM's are deleting sensors to save money and making up for them by using more complex math in the software. Having accelerometers on each wheel and a full sensor set on the body is not necessary, but it makes for more accurate calculations to control the damper. The result is that you get very smooth, fluid body motion all the time, with none of the unnatural "digital" feeling that some other cars have.
07-01-2014, 08:58 PM | #16 |
24
Rep 206
Drives: 2000 Z3, 2015 M4
Thanks for the report great info, but you are not making me feel any better about my salesperson leaving the adaptive suspension out of my order.
2000 Z3 2.3 2011 328 |
07-01-2014, 09:00 PM | #17 |
848
Rep 3,249
Thanks for the review! Sounds promising!
'21 /// M5 Comp - Frozen Brilliant White/Black
'18 Porsche GT3 Carrara White/Black/Red - Sold '18 /// M3 - Individual Imola/Black - Sold '15 /// M4 - YMB/SO - Sold '12 E92 ///M3 ZCP - AW/FR - Sold |
07-01-2014, 09:08 PM | #18 |
819
Rep 7,887
I read this review (which is very well written)and my M4 by way of an ordering error arrives with passive suspension.Now I am on the fence about taking my misordered car in the next 2 weeks or waiting till a properly equipped car arrives for me.What to do?
07-01-2014, 09:32 PM | #19 | |
1030
Rep 1,191
Either way, the passive suspension will be excellent too. Several people have already chimed in with rave reviews.
07-01-2014, 09:54 PM | #20 | |
24
Rep 206
07-01-2014, 09:59 PM | #21 | ||
24
Rep 206
