      05-25-2023, 02:00 PM   #23
Alpine Wait
71
62
Drives: 2018 X3
Originally Posted by JMD View Post
It's amazing that given the space the ICE takes up,...that there isn't a thought to add any "Frunk" space. Also, I have to admit,...and based on the animation, the ICE setup appears to be way more complexed than the BEV setup! Surprising!!!
Even more amazing is how much you notice how the 1000lbs of metal from the engine and transmission impacts driving/handling when you get used to an EV, then go back to ICE.
Distributing that weight to the floor is way more noticeable to driving performance than any improvement such as replacing a standard glass sunroof with carbon fiber. If BMW was really all about the performance/driving, they would have already switched to dedicated EV platforms for their performance cars.
baron951739.50
      05-26-2023, 08:01 AM   #24
sor
sor's Avatar
3115
3,076
Drives: 2023 iX M60 Oxide
2023 BMW iX M60  [0.00]
Originally Posted by JRobUSC View Post
They “couldn’t” fit it? Or they just “didn’t” fit it? Unless they flat out stated “the largest battery we could fit was this one” then I would fathom a guess that making sure there was no impinging on the (much more expensive) i7 was as much or more of a driving factor in the battery capacity decision as space was.
They probably chose the battery size based on a mix of things. A car like this is going to get good range with less battery compared to the iX, so they can afford not to put a gargantuan battery in and save some weight, try to maintain some driving dynamics.
      05-27-2023, 01:21 PM   #25
JMD
MGySgt
JMD's Avatar
642
1,260
Drives: See Garage List! ;-)
2010 M5  [10.00]
2016 BMW 340xi M Sport  [9.00]
2019 X5 50i M Sport  [5.50]
2010 535xi  [0.00]
2013 M5  [0.00]
2012 X5 M  [0.00]
Congrats!
JMD
      05-29-2023, 12:22 PM   #26
ChrisM4
ChrisM4's Avatar
1661
997
Drives: 2024 M4 Comp X-Drive
Originally Posted by Tag View Post
It's an animated GIF but since you can't see it I'll describe what it shows as succinctly as I can. The entire powertrain morphs from ICE to a fat bloated pig.
I literally spat out my coffee onto my keyboard 😂
2024 Dravit Grey M4 Competition X-Drive
      05-29-2023, 03:09 PM   #27
brad850csi
1319
2,352
Drives: 16 F13 M6 Comp
With the batteries under the floor there must be one of these outcomes or possibly a mixture of all 3?
Less leg room height
Less ground clearance
Higher overall vehicle height
From BMW press - the overall height then ground clearance:
1515mm 146mm i5 edrive40
1505mm 136mm i5 M60 - this would imply the suspension is 10mm lower
1515mm 154mm 520i and 520d
So this would imply that the battery sticks down about 10mm more than a normal petrol car would.
Unfortunately the press release doesn't list leg room but I'm guessing that some is lost with the i5 versions.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
