08-20-2011, 07:09 AM | #23 |
Track Addict
119
Rep 813
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
Now truthful question, not that I would do it but because of curiosity, would using cheapest gas from chevron damage the engine in the M3?
BMW ///M3 Coupe
Completed November 16, 2009 Received December 29,2009 |
08-20-2011, 07:16 AM | #24 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
bullsh*t, a simple proof; log your ignition timing with 91 octane, and log it with 93 octane, you will notice why 93/premium fuel should be used in performance engines.
08-21-2011, 01:48 AM | #25 |
81
Rep 1,644
... Don't use the Euro RON number to base your numbers. 95 RON is pretty much 91 AKI. No need to go 98 RON (roughly 94 AKI).
Former car
2011 BMW 335i Step - Montego Blue / Chestnut Brown |
08-22-2011, 11:26 AM | #26 |
Rep 6
It's really pretty simple (this is by no means a scientific explanation, car guy language only):
In simplest terms, Octane with the temperature in which gasoline will burn. Higher the number, hotter the temp. What does this mean? With higher temps, you can have higher compression, with higher compression, static or organic, you can have more performance. Timing is a big factor in HP. Typically if you have a car that has more timing or advanced timing, you have a higher performance car. Formula is as such ( again car guy language), typical rule of thumb: more octane + more compression + more timing = MORE POWER.. However, in todays computer control vehicles, you can't pop the hood and turn the distributor and gain 10 HP like the old days. Factory direct manufactures timing curves are capped, regardless of fuel. Knock sensors have eliminated the need for premium fuel in 'economic' cars. However, the performance or 'factory' dialed in performance cars are engineered to peak with 'premium' fuel. Manufactures tweak timing and compression for max, to a point, power and in doing so with require a premium fuel. Does that mean they will run without premium? Of course. Does non premium fuel hurt the engine? No, knock sensors prevent that Does non premium fuel hinder performance and mileage of a 'performance or premium fuel' engine? Yes Also another thing about Octane, very high octane gas (race gas, 101, 110, 120) is not a good idea unless you are running a static compression of over 13:1 or turbo/supercharger. High octane gas requires high ignition temps but actually burns cooler.....odd I know....and can cause damage is abused or used in a situation that is not designed for such. |
08-22-2011, 12:03 PM | #27 |
1985
Rep 4,230
Drives: BMW G80 M3
Stupid article - to which less-than-astute readers will go forth assuming premium fuel is a scam. Way to mislead the readers ...
Why would BMW require 91+ if they didn't have to? Wouldn't it be a selling point if the car was able to use 87? C'mon ...
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
