05-01-2014, 01:41 PM | #1 |
12
Rep 85
Tire Rack?
Did anyone else notice Tire Rack no longer lists tires or wheels for the 2014 M235i? And that they ask if it was built before or after 3/2014? What changed on the March builds?
Thanks! |
05-01-2014, 09:00 PM | #2 |
65
Rep 326
Drives: 2020 X3M40, 2000 Z3M, 2017 X1
Same thing for the 228i. Maybe they are just setting up the site to show wheel/tire packages etc. Not sure what the big deal is, the 2 series seems to have the same offsets as the 1 series, so all the 1 series wheels should fit.
05-02-2014, 10:11 AM | #4 |
108
Rep 587
Drives: 2020 M2C
From what I've seen (and I have been checking since early March) they have never had 235M info on their web site. I also called them right after I took delivery, and they said they hadn't gotten a 235M in yet to test packages on.
I just hope they have something by this Fall when I'm going to be in the market for a Winter set-up |
05-02-2014, 11:18 AM | #6 |
108
Rep 587
Drives: 2020 M2C
Thanks! Missed that when I went back to their site the other day and figured they still hadn't updated it yet. Weird on the build date stuff. My car was built mid-February and the site says on or before 2/2014 or on or after 3/2014? I guess I go with the 2/2014 then, but I also wonder what the difference is. I don't see anything obvious on the web site (the same tires come up).
Update: The difference on build date is the TPMS BMW used. This according to the tech I just talked to at Tire Rack. There was a change made in March. Last edited by golf4501; 05-02-2014 at 11:27 AM.. |
05-02-2014, 01:56 PM | #7 |
12
Rep 85
05-02-2014, 02:12 PM | #8 | |
51
Rep 99
Summary: Week 10+ builds have different TPMS, which throws warning if removed. Two options to fix: 1. buy/install new sensors on aftermarket wheels, or 2. code it out. |
05-02-2014, 02:57 PM | #9 |
4518
Rep 8,942
Was told by Gill at tire rack if you select 2013 135is all those wheels should fit, just FYI
2022 Macan S
05-03-2014, 09:23 PM | #10 |
65
Rep 326
Looks like Tire Rack has updated their site to show wheel and tire packages for 228 and M235. Includes selection for winter packages.
