      04-12-2014, 10:37 AM   #1
Gaviin
Gaviin's Avatar
17
131
Drives: 2017 M2
Bug with thread paging
There seems to be a bug with the way pages are determined within threads. Quite often, there will be threads that appear to have a subsequent page, but if you click to that page, it will go to the "second-to-last" page instead, which is the true last page because there are no further posts. In other words, the page links at the top and bottom of the threads are wrong.
As of posting this bug report, the following thread (which has 220 replies) is demonstrating this problem: http://www.2addicts.com/forums/showthread.php?t=923208
If you click to "Last Page", it will bring you to page 11, even though the thread links show 12 pages. There's no way to get to a 12th/final page.
This occurs with both the default setting for "Number of Posts to Show Per Page" (which I believe is 20), and setting it specifically to 20 per page.
Something else is strange because with the thread above, if you look at the post count numbers in the upper-right of each post, they go up to 220... though the thread page says there are 220 *replies*, which indicates the numbers should go up to 221 (initial post + 220 replies). In the same sub-forum, there's another thread (http://www.2addicts.com/forums/showthread.php?t=953206) that says it has 61 replies, and the post counts correctly go up to 62. So in the same sub-forum, you have two different behaviors. Odd.
