12-15-2005, 07:16 AM | #1 |
Guest
Rep n/a
Drives:
320 Diesel driving skills
Can someone advise me i just purchased a 320 diesel and are not sure how to use this car to its fullist. What i need to know moving from 320 i to diesel needs some adjustment ,should you just fully accelerate to make the most of the turbo boost please help im new at this
12-15-2005, 07:24 AM | #2 |
S0THPAW
9022
Rep 7,867
Ok mate. I previously owned a E46 330d manual and drove a 6sp 120d for half a year(same engine)
The low end torque means you can easily shift at 3000rpm and still go with the flow. Max rpm =4500 but when you shift at 4000 you will go fast enough. Break it in nice and calm and with loads of different revs somewhere around/below 3000 or 3500 max. Cold start:same thing. Cool down after driving fast(er):keep the engine on idle for a minute or so.(because of the spinning turbo which needs to slow down first) Cheers. Robin
'I won't say anything 'cause no one listens to me anyway....I might as well be a Leonard Cohen record' -Neill
12-15-2005, 10:08 AM | #4 |
118
Rep 2,333
Yep, as Robin said, no point stretching beyond 4k rpm as there's more to be gained by changing up early. Don't be surprised if you stall it a few times taking off from rest - it needs a few revs. Once above 1500rpm the turbo starts spinning and it starts to fly. Basically, you want to keep it in the 1500 - 4000 band and you'll be fine!!!
Current: F13 640i MSport, e85 Z4 3.0i
Previous - Alpina D3 BiTurbo E90 LCI Manual, 320d M Sport E92 Auto, 330i M Sport E92 courtesy of BMW UK....320i M Sport E92 Auto, 320d SE E90 Manual. |
12-15-2005, 12:11 PM | #5 |
43
Rep 463
When I floor it, people always get a fright! It's hilarious! Nothing, nothing, then 1800-2000rpm, 340Nm torque, and BAM! We're off! I absolutely love it. I'm extremely happy with the 320d and you will be too. Once it's properly broken in, take it to a quiet but open road with some twists and turns and just experiment.
PS: Just saw you are from South Africa. We have a couple of members with 320d's from ZA (broken1 is the first that comes to mind). Maybe he can give you some tips on where to experiment.
E90 320d - Black Ext/Fluid Grey Int | Steptronic | Business Navigation | PDC | Sunroof | Alarm Exterior Pictures | Interior Pictures | Video |
