      06-01-2013, 05:41 AM   #1
rphan2
34
Drives: na
So my sister's Accord just died...
My sister has a 2000 Honda Accord Ex and this has happened a few times already. While driving, the car would slow down and just shut down completely. Like the engine dies and the lights in the dashboard light up. WTF? We just start the engine right back up and it drives like normal again. I have taken the car to 10+ mechanics and no one can put a finger on what's wrong. This is crazy when the car just dies all of a sudden. The only warning I think we get is the car will vibrate a lot more then usual and that means the car is about to shut down? Any ideas before I take it to another mechanic? Is there anything specific I can ask them to check? Maybe something electrical? The last time we had something fixed for this was the idle.
      06-01-2013, 08:38 AM   #2
!JGunz_325
11
70
Drives: AW 325i Sport
Flux capacitor might be damaged.
      06-01-2013, 10:08 AM   #3
Mr Tonka
is probably out riding.
Mr Tonka's Avatar
6062
2,292
Drives: Something Italian
So very sorry for your loss. Our thoughts and prayers are with you and your family.
http://www.m3post.com/forums/signaturepics/sigpic59612_1.gif
      06-01-2013, 10:38 AM   #4
upstatedoc
I'll get back to you
upstatedoc's Avatar
7547
2,132
Drives: blue streak
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/
Countermeasure enthusiast.
      06-01-2013, 11:39 AM   #5
AndreyT
AndreyT's Avatar
59
1,038
Drives: 2011 335i Sedan, Sport
Originally Posted by rphan2 View Post
My sister has a 2000 Honda Accord Ex and this has happened a few times already. While driving, the car would slow down and just shut down completely....
Even though this sounds very much like that well-known problem with BMW e9x, which would just shut down because of loss of battery power while driving (some believe that the recent battery connector recall is supposed to address that issue), I think you will have much better luck asking this in a Honda [Accord]-specific forum.
      06-01-2013, 01:08 PM   #6
boostedTIAG335
boostedTIAG335's Avatar
11
Drives: E92 335i
Buy her a new car?
2008 TIAG E92 335i 6MT
Mods: Tinted Windows (35%), Aero Lip and JB3...for now
      06-01-2013, 01:30 PM   #7
rphan2
34
Drives: na
Originally Posted by AndreyT View Post
Even though this sounds very much like that well-known problem with BMW e9x, which would just down because of loss of battery power while driving (some believe that the recent battery connector recall is supposed to address that issue), I think you will have much better luck asking this in a Honda [Accord]-specific forum.
The battery was just replaced last week. This has happened a few times and it's scary not knowing when or why the car will just stop and shut down. Just looking for ideas to ask the mechanic. I tried the Honda forums, but not getting much help.
      06-01-2013, 01:33 PM   #8
Colt
Spoolin' & droolin'
Colt's Avatar
106
1,229
Drives: 08 135i 6MT
Friends old 1998(?) accord did the same thing. Ended up being the ignition and replaced it. Think he also replaced the alternator and battery too.
Originally Posted by Nate4641 View Post
looks like unicorn vomit.
      06-01-2013, 10:51 PM   #9
Bakeme521
Some say...
Bakeme521's Avatar
255
4,296
Drives: Fresh
2007 BMW 335i  [8.24]
Guaranteed either the main relay or ignition mechanism.
I have exhaust and an intake...
      06-02-2013, 12:42 AM   #10
Vic311
42
1,462
Drives: 2011 e92 M3
Have you checked the head gasket. Tell tale sign is the shudder before stall out (water leaking into the combustion chamber)
The fact that it starts right back up tells me it's not electrical. Those cars use caveman ECU's, as long as you have spark, fuel and air that engine will run
      06-02-2013, 04:37 AM   #11
Arben72
Albania
54
462
Drives: E92 M3
Water in the gas tank? Long shot but it won't hurt to check.
      06-02-2013, 07:42 AM   #12
rphan2
34
Drives: na
Thanks guys, sounds like it might be an ignition or relay problem? I'll ask this week. Any ideas what price range this should cost?
      06-02-2013, 12:00 PM   #13
M3Denver
M3Denver's Avatar
22
420
Drives: 2011 BMW M3
Check air intake tubing for cracks. Cracks are sealed When Cold. When engine heats up crack opens and the get engine sputter and stall/shutdown.
      06-02-2013, 01:48 PM   #14
rphan2
34
Drives: na
When the car died, we just put in back to the "P" position and start it right back up, no problems. So I would think it's not really an ignition problem? A few others have told me it's an electrical issue? I'm not sure if this matters, but the few times this has happened, the weather is usually pretty hot.
      06-03-2013, 11:14 AM   #15
JasonCSU
712
2,548
Drives: '08 135i, '88 325is
1988 BMW 325is  [0.00]
2008 BMW 135i  [0.00]
I've had the ignition issue like some have mentioned with my old Acura Integra. Basically, the ignition switch had become so worn that the key would sometimes turn on its own from the On position to the Accessory position causing the engine to shutdown while driving. Your mention of the car vibrating before it stalls makes it sound more like a mechanical issue than an electrical one though.
Delivered in Munich, broken in on the Nurburgring.
      06-04-2013, 11:25 PM   #16
Bakeme521
Some say...
Bakeme521's Avatar
255
4,296
Drives: Fresh
Def not, this is def sign of an electrical issue. The fact that it does die and starts right back up fine shows that it IS electrical. Esp the fact that the lights do crazy stuff inside the car. I work for a company that works on hondas, and I have seen main relays and ignition mechanisms go out countless times with those exact symptoms. Not saying I'm 100 percent right, but I'd put money on it being electrical.
      06-04-2013, 11:29 PM   #17
Luong
Luong's Avatar
27
332
Drives: M4
hahaha
IG: @MrLuong
      06-05-2013, 01:55 PM   #18
06E90Rostik
2006 join date crew
194
1,482
Drives: 2006 325i, 2011 335i
2011 335i  [10.00]
2006 325i  [0.00]
Strong join date to post count ration. One post per year
      06-07-2013, 11:02 AM   #19
TSM330i
2006 330i, TSM, Black, manual, sport
TSM330i's Avatar
906
3,698
Drives: '17 C2, GTI, Z4 3.0si Racecar
Check to make sure there is no dirt or anything else in the gas tank/fuel system.
2017 Porsche C2 - manual of course
2015 GTI S
2008 BMW Z4 3.0si Coupe - because racecar
      06-07-2013, 11:09 AM   #20
upstatedoc
upstatedoc's Avatar
7547
2,132
Drives: blue streak
i'm dying to know what happened to OP's sisters accord.
2018 Stinger GT
      06-08-2013, 04:57 PM   #21
rphan2
34
Drives: na
Lol...I took it in to a shop that only specializes on Hondas and described the issue with them as best I can. The guy told me I had to schedule an appointment for a complete diagnosis and it would cost 90 bucks. I left and said I'll think about it since I had to leave the car there all day. I don't know, is it worth it to get this diagnosis?
      06-08-2013, 05:09 PM   #22
OOO
OOO's Avatar
32
310
Drives: in the slow lane
It's time to turn her into the dark side...
E92 BMW M3|Space Gray|DCT|Performance Splitters|Carbon Fiber Mirrors|Performance Spoiler
Tags
negged for fraudin
