09-18-2007, 06:25 PM | #1 |
***** noob
1422
Rep 10,477
True or false.....how to save money at the pump
not sure if this is true, but its interesting to know
Fill up your car or truck in the morning when the temperature is still cool. Remember that all service stations have their storage tanks buried below ground; and the colder the ground, the denser the gasoline. When it gets warmer gasoline expands, so if you're filling up in the afternoon or in the evening, what should be a gallon is not exactly a gallon. In the petroleum business, the specific gravity and temperature of the fuel (gasoline, diesel, jet fuel, ethanol and other petroleum products) are significant. Every truckload that we load is temperature-compensated so that the indicated gallonage is actually the amount pumped. A one-degree rise in temperature is a big deal for businesses, but service stations don't have temperature compensation at their pumps. If a tanker truck is filling the station's tank at the time you want to buy gas, do not fill up; most likely dirt and sludge in the tank is being stirred up when gas is being delivered, and you might be transferring that dirt from the bottom of their tank into your car's tank. Fill up when your gas tank is half-full (or half-empty), because the more gas you have in your tank the less air there is and gasoline evaporates rapidly, especially when it's warm. (Gasoline storage tanks have an internal floating 'roof' membrane to act as a barrier between the gas and the atmosphere, thereby minimizing evaporation.) If you look at the trigger you'll see that it has three delivery settings: slow, medium and high. When you're filling up do not squeeze the trigger of the nozzle to the high setting. You should be pumping at the slow setting, thereby minimizing vapors created while you are pumping. Hoses at the pump are corrugated; the corrugations act as a return path for vapor recovery from gas that already has been metered. If you are pumping at the high setting, the agitated gasoline contains more vapor, which is being sucked back into the underground tank so you're getting less gas for your money. Hope this will help ease your 'pain at the pump'.
2006 325xi (Sold)
09-18-2007, 06:50 PM | #3 |
Modaholic
97
Rep 1,707
Haha... I guess it could be true, even if it is marginal... Even Jeremy Clarkson on Top Gear said so when he was doing an episode where he was trying to drive the Audi A8 for 800 miles on a single tank of diesel.
Euro Delivery - April 2007
09-18-2007, 06:50 PM | #4 |
STEVIL Empire
226
Rep 6,297
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
09-18-2007, 07:12 PM | #5 |
32
Rep 799
I thought someone posted this already saying it came "direct from his cousin" or something who works in the oil industry?
Edit: Ah, yes. Heres the thread: http://www.e90post.com/forums/showthread.php?t=81169 |
09-18-2007, 07:12 PM | #6 |
1731
Rep 14,825
I think only one condition has to exist to negate the significance of what the OP says......you make minimum wage or higher.
I think it's like the old Philadelphia wives tale that our granpas told us...never buy a pretzel on a rainy day. He said they could not get the dough to rise on such a day so necessarily the pretzel sold is from the day before and reheated. Whether it's true or not again, is not consequential if you make minimum wage or higher.... |
09-18-2007, 07:17 PM | #8 |
148
Rep 6,333
Savings are minimal.. not worth the time imho.
2017 BMW M4 DCT Lease Transfer: https://f80.bimmerpost.com/forums/sh...8#post23736398
09-19-2007, 12:33 PM | #10 |
33
Rep 1,284
That’s a pretty ignorant statement. People purchase what they can afford and/or what they like. I'll show a BMW owner the same respect I'd show a Honda owner. A car enthusiast is a car enthusiast in my opinion. Anyway about this thread.. Its not a question about being able to afford gas, but if its something as simple as the time of day when you fill up could save you some money why not? I agree with if the savings are minimal then its not worth going out of your way for.
09-19-2007, 01:00 PM | #11 |
Rep 181
Drives: 2007 E90 335i
Each of those tips could theoretically get you more gas for the money, but it's probably a few drops per tank max. You might as well give the nozzle a little shake before you yank it out to put another drop in. IMHO the savings aren't worth the effort.
2007 E90 335i
Black Sapphire | Black Leather | Aluminum 6MT | ZPP | ZSP | CA | Heated Seats | 6FL 35% Tint | Golf Tee |
09-19-2007, 01:03 PM | #12 |
Klaatu Barada Nikto
30
Rep 1,169
09-19-2007, 01:59 PM | #13 |
259
Rep 6,664
I'm taking an educated guess and saying that the ground doesn't really change temperature on a daily basis at the depth the tanks are located. And any extremely small temp delta there would be would lead to an extremely insignificant difference in pumped fuel. For the first few inches of earth, maybe, but once you're down several feet, ground temp becomes very constant. That's why geothermal heating can work the way it does, and those pipes aren't buried that far down..
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER. |
09-19-2007, 02:09 PM | #14 |
259
Rep 6,664
My hypothesis:
I think the OP is pumping too slow, extending the amount of time that he is exposed to inhale said gas vapors. This is leading to posting absolute nonsense such as the above information and should not be taken seriously.. j/k ska...
09-19-2007, 02:18 PM | #15 |
401
Rep 2,984
"...I maybe drunk, but you're ugly, and I can sober up..." |
09-19-2007, 06:08 PM | #16 |
***** noob
1422
Rep 10,477
2006 325xi (Sold)
09-19-2007, 06:09 PM | #17 | |
***** noob
1422
Rep 10,477
Honda uses gas too...no??
2006 325xi (Sold)
09-19-2007, 07:35 PM | #18 | |
Freude am Fahren
356
Rep 5,254
Freude am Fahren.
Jonathan E90 2006 330xi E90 2006 325i E39 2003 530i Sport* E46 2000 328Ci* E36 1996 328iS* E36 1992 325i* E30 1991 318is E21 1982 320iS* E21 1979 320 (6-Zyl)* *retired Nominated: Most Contributing Member |
09-19-2007, 09:13 PM | #20 |
1911
Rep 4,123
Drives: M235i & G30 540i
I don't really care too much about gas prices, cause I love to drive. That trumps the high prices to me. But if you are really serious about saving gas, the best way to do that is to car pool.
If you must drive here are a few pointers. 1. Drive at a steady pace, and gradually increase speed from a stop instead of stepping on it after every stop. 2. Keep your car free of anything that increases the weight to your car. So dirty trunks with junk in it, and back seats full of things that you don't need there is making your car use more gas. 3. Keep your tires inflated at the right psi (this is one of the most important and most neglected pointers) 4. Avoid spirited driving. The harder you step on the gas and the brakes continuously for long periods is the more gas you will burn. And finally don't waste your time buying those silly gadgets that profess 15% and 25% gas savings. Like most things in life, IF IT SOUNDS TOO GOOD TO BE TRUE, IT USUALLY IS.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
09-19-2007, 09:45 PM | #21 | |
Ski bum
331
Rep 6,198
1999 e46 328i Ti Silver / Black[retired] 2007 e90 335xi Jet Black / Black[retired] 2011 e70 X5 35d Vermillion Red / Cinnamon 2011 e92 M3 LeMans / Fox Red extended |
09-20-2007, 11:14 AM | #22 |
Mack
28
Rep 209
^^^ HAHAHA^^^
2006 BMW 325i / Jet Black / Black Dakota / Step / Nav w/ iDrive/ Premium / Sport / Sat Radio/ Adaptive Xenon Headlights / Debadged / Chrome Exhaust Tips / Rear Foglight Mod. / Rear DC Power Outlet Mod. / 20% Tint
