F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Why no Fuel Cut when slowing down?
Studio RSR
      05-28-2013, 04:49 PM   #1
momo3605
209
1,201
Drives: M340i LCI, 718 GTS 4.0
When slowing down, once i get to about 40mph, even while braking, the mpg counter drops to like 60mpg, this is pretty dumb...i thought with the efficient dynamics, battery charging/auto start-stop eco facade, it would atleast be able to be gasless while slowing down. Even my M3 stays at 99.9 mpg up to the last second before coming to a complete stop.
      06-01-2013, 03:04 AM   #2
SomeRandomer123
SomeRandomer123's Avatar
England
310
2,612
Drives: F30 328i Luxury - Sport Auto
I get 99.9 on the live MPG read out (BC) on the Black Panel when decelerating and the red live MPG on the full Black Panel display goes into the EfficientDynamics blue area as Brake Energy Regeneration is taking place.
When coasting or braking (decelerating), the alternator engages to return charge to the battery. Our alternators are not engaged at all times so load on the engine is reduced - thus giving full engine power and maximum efficiency as the engine does not have to work as hard.
As I believe, but can't confirm 100%, the engine uses no fuel when decelerating (off the throttle) as the spinning wheels are obviously turning the transmission, which is turning the crank, which is driving the pistons.
I do want to learn more about what the engine and engine management is up to with regards to fuel efficiency when decelerating - especially as the new ECO PRO mode is supposed to disconnect the transmission (N) when decelerating to save fuel. Bearing in mind what I've just said and believe to be true, surely the idling engine is using more fuel than the decelerating engine?
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      06-01-2013, 03:53 AM   #3
momo3605
209
1,201
Really? I'm not getting 99.9 when slowing down. But I have found that once my rpm's fall below 1200 or so, the transmission disconnects from the engine and then the mpg drops to 60ish cuz I guess the engine has to turn back on. If I put the car into S and slow down, the transmission stays engaged and I stay at 99.9 up until right before I stop.
f30post
