BMW 3-Series (E90 E92) Forum
Creative Autoworks Suspension GB!
11-29-2005, 07:06 PM | #1 |
29
Rep 392
As requested, We will host a suspension GB for the E90’s with the two of the best in the business H&R and KW. Call if you would like a price on H&R coilovers. The most popular spring in H&R's line-up, Sport Springs will lower your vehicle an average of 1.5 - 2 inches (depending upon the make and model of your vehicle) for a lower center of gravity, improved handling and a more aggressive appearance. Sport springs feature more control than that of the OE Sport spring, but is still comfortable for daily use. Sport springs are an excellent choice for street and occasional track use. H&R Sport Springs E90 325i, 330i Sedan ~ (f) 1.3” (r) 1.2” **Part Number: 50490 $255 shipped H&R Sport Springs E90 325Xi, 330Xi Sedan ~ (f) 1.3” (r) 1.2” **Part Number: 50494 $255 shipped H&R Sport Springs E91 325Xi Sport Wagon~ (f) 1.3” (r) 1.2” **Part Number: 50494-2 $270 shipped For the discerning enthusiast that wants the ultimate in performance and an aggressive look, H&R Race Springs are the perfect solution. H&R Race Springs will lower your vehicle approximately 1.75-2.5 inches (depending on the make and model of your vehicle) and should be matched with high-quality, sport-tuned shock absorbers. Camber correction may be necessary, for H&R camber solutions check H&R's Triple C Camber Adjustment Bolt application guide. H&R Race Springs E90 325i, 330i Sedan ~ (f) 2” (r) 1.5” **Part Number: 50490-88 $255 shipped CALL us for prices on KW coilovers!!! Prices are too good to pass up. Last edited by creativeautoworks; 11-29-2005 at 07:49 PM.. |
11-30-2005, 10:25 AM | #3 |
17
Rep 156
What are the spring rates of the sport springs compared to stock? i.e. are they 100 lbs stiffer or more, are the fronts stiffer than the rear, or are the front/rear the same rates? I'm guessing dropping over an inch will probably add about a half of degree of negative camber. In any case, stiffer springs and more negative camber will help the cornering a noticable difference.
11-30-2005, 01:07 PM | #5 | ||
29
Rep 392
Sport Springs do not lower the car as much and the spring rate is NOT as aggressive as the Race Springs. Quote:
12-04-2005, 11:23 AM | #9 |
19
Rep 199
Aggresive drop = aggresive looks, specially when mated with 19" or 20" wheels. Its mostly about the looks aka reducing the wheel gap.
'13 E92 M3 ZCP DCT
Prev:'06 E90 330i ZSP, '12 Mustang 5.0, '15 VW GTI |
12-04-2005, 09:22 PM | #10 | |
189
Rep 1,855
12-06-2005, 01:13 PM | #11 | |
29
Rep 392
Some drivers just like to feel the road a little but more, also feel that they can maneuver the car slightly better with an aggressive ride. |
12-13-2005, 12:59 AM | #14 |
your average JAMF
3188
Rep 4,110
Drives: '21 M2 Comp, '19 Golf R
H&R Race springs + runflats? Unless you drive exclusively on airport runways, pool tables, or gymnasium floors, OR only use your car for weekend track/autocross events, I HIGHLY recommend against this setup on your daily driver. If you do opt for it, be sure to order a kidney belt at the same time, you'll need it.
'21 M2 Comp
'19 Golf R |
12-18-2005, 09:56 PM | #17 | |
28
Rep 537
12-19-2005, 01:11 PM | #18 | |
189
Rep 1,855
12-19-2005, 02:02 PM | #19 | |
16
Rep 926
12-19-2005, 09:00 PM | #20 | |
your average JAMF
3188
Rep 4,110
'21 M2 Comp
'19 Golf R |
12-19-2005, 10:43 PM | #21 | |
16
Rep 926
12-20-2005, 09:36 AM | #22 | |
28
Rep 537
