BMW 3-Series (E90 E92) Forum
Changing Interior Trim - DIY
11-23-2005, 04:16 PM | #1 |
Lord Of The Fjords
38
Rep 134
Drives: 325i Coupe
I received my aluminum trim today and thought it would be hell to change my plastic aluminum trim to the real thing, but it was very easy. You just have to use power.
I started out with the door handles. They were the easiest to change. I used a flat screwdriver to lift up the outer end of the trim. I lifted it enough to get my finger under it. Then it's just to pull it slowly from one end to the other. Use power, but do it slowly. The trim will be released from the clips. I then put the new ones on. Very easy. This goes for all of the doors. Now for the dash... A bit more time consuming, but quite easy. Use the flat screwdriver again and lift the right side of the trim (by the right door). The air ventilator will also come off. When you have reached the center of the dash (where the dual ventilators are) you need a torque key (size 10) to unscrew the two screws that holds the center ventilators to the trim. When they are unscrewed you work on the key hole. It's clipped on. Unclip it on the backside and take the outer part of the key "ring" and button out. The ventilators on the right side and in the middle is also cliped on the trim. Unclip them and you will release the whole trim panel. Reverse this order for putting the new trim on. The left side of the wheel is easier. Just do the same as above. Now for the toughest part - The center console (non iDrive) First you have to pull up the gear frame. It's easy, but you need to use a bit of power. When it's up you can take off the whole console (Don't forget to lift up the armrest). The you need to unscrew the four screws that holds the ashtray to the trim. When you're done, unclip the storage bin (by the armrest). Then you need to clip off the ashtray trim. Also, clips. To put on the new console, repeat what you just did. I aslo changed the trim on my steering wheel. I had the same alu plastic trim, but wanted it black, so it would look better with the real aluminum. Use the torque (same size) to unscrew the three screws behind the wheel. The unclip the plastic trim. The controls will need to be unscrewed from the trim. Repeat the whole process to put on the new trim. All in all I used around 1,5 hour. Next time I guess I can do the same thing in 30 minutes. By the way, I have a complete plastic alu set for the E90 if anyone wants it cheap. Good luck! C |
04-10-2006, 10:51 AM | #5 |
Rep 11
Trim Removal
Can you tell me more about replacing the center console trim? What is the gear frame? What are you pulling up? Any help with more details would be appreciated. Thanks.
Peter
1980 320i sport 1986 535i 1998 Z3 2000 323Ci 2003 540i sport 2006 330i |
04-11-2006, 10:05 PM | #6 |
***** noob
1380
Rep 10,479
Pics please
2006 325xi (Sold)
11-19-2006, 12:55 AM | #8 |
19
Rep 269
Where did you get the aluminum trim, and how much did it cost?
Thanks.
Retired: '00 e46 (5mt)
Retired: '07 e92 (6mt) Current: '08 S2000 (6mt) Current: '17 Porsche Macan GTS Current: '04 V8 4Runner |
11-25-2006, 11:13 PM | #9 |
Doctor of Journalism
28
Rep 352
I'm getting delivery this week of a 335i coupe with coral red and dark burl walnut trim. I would like aluminum.
I have idrive. How much for the trim itself? |
12-12-2006, 12:26 PM | #11 |
85
Rep 2,221
nice write up. yet it would be nice enough to see some before and after pics.
03-22-2008, 04:43 PM | #14 |
635
Rep 24,685
Drives: '04 330i ZHP
it was a lot easier than I had thought... only had parts were 1. reinserting the wiring for the hazard lights by hand... that took about 10 min to slip it in there, they dont give you much room to work. and 2. popping off the ashtray cover without breaking any clips.
anyway heres a few pics from my install. |
04-02-2008, 12:29 AM | #17 |
635
Rep 24,685
04-02-2008, 06:20 PM | #18 |
19
Rep 459
Drives: E90 335i w/ZSP
11-11-2008, 07:15 PM | #19 |
Juicy Booty NomNoMnom
49
Rep 1,204
okey guys, so I just tried to remove my Trim and i followed the OP's directions, but i feel like im going to snap the vinyl. How much power is power?! I mean if someone could put it into perspective for me?
19" Monarch 410 Staggered || Matte Black Grill || 4" Exhaust Tips || Dual Intake || GP Tunders 7500K || Money Tints || JB2 ||Custom Start Button || Updated!
