      09-23-2012, 11:19 AM   #1
D_o_S
LCI'd
276
822
Drives: 335i LCI
Do YOU cut corners?
Hiya,
I'm in Europe, so here we drive on the right (steering wheel is on the left). I always get fed up when I'm approaching a right turn, only to find a car taking up half of my lane... Usually, this ends up with me braking/stopping...
I've considered doing several things. First of all, I believe cutting corners can increase safety, however only if it's done at the right time and place. However, there are often times when I see drivers doing it plain wrong: they leave me no room to drive through the right turn.
My question is: what do I do? Do I hold my path and try to go past and crash into the other car if there's no more room? I.e. can I rely on the other driver to move over as soon as he sees me? Also, when approaching a right turn, I have considered driving over the dotted line to straighten out the corner when approaching it - however, what will the guy coming the opposite way think?
So, should I cut corners or not? Do you do it? Do you find it safer? Or are you just too lazy to turn the wheel?
      09-23-2012, 04:07 PM   #2
michaelthepsycho
michaelthepsycho's Avatar
Taiwan
82
1,644
Drives: 11 Montego Blue E90 335i Step
Nobody should cut corners, ever. At least not at the hilarious speeds I've seen people corner at. Apexing is for VERY high speeds only. I don't have that problem here.
Former car
2011 BMW 335i Step - Montego Blue / Chestnut Brown
      09-23-2012, 06:17 PM   #3
boymonkey
Taiwan
43
530
Drives: slow
I don't. It's not necessary on the roads unless you're going faster than you can handle, and that's exactly how it looks when someone can't stay within their lane.
      09-23-2012, 08:33 PM   #4
username604
username604's Avatar
128
2,554
Drives: bmw
2008 BMW 335i  [10.00]
if you aren't in the inner lane around a bend, DO NOT CUT CORNERS.
i consistently pass people on freeway ramps and round abouts, and there isn't much on the road that annoys me more than someone shifting over into my lane as i pass them, causing me to brake hard just to avoid them hitting me.
if you want the shorter curve, then get in the correct lane before the bend.
