06-14-2012, 12:45 PM | #1 |
82
Rep 251
Drives: E82 N52 6MT A51
Kellners N20 ECU Software Tune On SALE!
At bavauto.com , Kellners Sport module is Normally $1959.00 but its on sale for $1595.00. Check it out it offers +49 HP and +51lb.ft torque for the 328i F30
06-14-2012, 01:13 PM | #2 |
54
Rep 453
That still seems exorbitant to me especially in light of the dearth of information concerning what it does, how safe it is, and any independent validation of the horsepower results. This product is a costly gamble IMHO...
06-15-2012, 12:50 PM | #3 |
82
Rep 251
No it is costly but not a gamble. Its the best tune you can get for any BMW. Other tuners have engine signal interceptors and ECU reprogramming. This does neither of those. It is an OBDII piggyback cartridge with a 2nd ECU chip. Its plug and play. Plus kellners extensively tests all tunes on the track. By far this is the safest tune you can buy for your car. Even Dinan does not offer this, they only do ECU programming.
06-15-2012, 06:24 PM | #4 | |
54
Rep 453
06-16-2012, 04:19 AM | #5 |
82
Rep 251
I did some extensive research on F30 chips before purchasing since in canada I could fully load the 320i and get a performance chip for the n20 engine if i wanted a little extra power. What i found was stock internal ECU programming changes the original car to a warranty voided tuner. I then found Kelleners Sport. I did some heavy research on them and found they are a renowned performance tuning company from Germany for BMW's. They were the first with any tune for the F30 and it turns out its the best. check there site and youtube. All there upgrades are tested heavily on the track (they are german as we know nuts about performance, reliablity and all that jazz). It does not throw any codes as its only piggybacking. No info on the car is touched. When plugged in the BMW computer is bypassed and only the chip is doing all the work. When ur finished you just remove the cartridge from under the glove box and the car is back to factory state.
06-16-2012, 09:53 AM | #6 |
54
Rep 453
The tune detection code does not show to the end user. It is stored in the ECU and only detectable by a dealer. Just because you aren't seeing a light on the dash does NOT mean there are no tune detection codes in the ECU.
Do you have this product installed in your car? What steps are involved in the installation? Is the map upgradeable by the user? How does the tune handle additional modifications to the car, such as an intake and down pipe? Are you willing to put your car on a dyno with wideband 02 and boost monitoring and report back to the community? What is your affiliation with the manufacturer, if any? |
06-16-2012, 12:30 PM | #7 |
82
Rep 251
A tune code only shows if the onboard electronics and code are changed. All BMW engines are limited at the factory, and all this chip does is safely increases that limitation. Obviously reliability is compromised a little for extra engine power and increased component wear. Adding other mods like exhaust and cooling is just bonus performance and increasing reliability. Now I am not affiliated with this company, but I do have much work experience pertaining to control systems of any nature. Now I would recommend getting this tune for the 320i, since at that mod the engine is still below BMW's set limitation. For the 328i and 335i you are now pushing the engine harder than BMW set it for, but should not be much of a problem since these engines are quite resilient.
Read this: http://www.kelleners-sport.com/en/performance.php If you can, give them a call. (its a call to germany) They say on the site that the chip can be removed without leaving a trace behind. Which makes sense since no code/electronics are touched in the car, they are all located on the cartridge. |
06-16-2012, 02:03 PM | #8 |
54
Rep 1,544
AC Schnitzer is also making a piggy-back module for the N20, & in Europe at least, it retains full BMW warranty as for a number of countries it is represented by the local BMW importer.
06-16-2012, 03:32 PM | #9 |
82
Rep 251
nice, i'll check that out.
06-17-2012, 07:49 AM | #10 | |
54
Rep 453
Do you have this device on your car? |
06-17-2012, 03:28 PM | #11 |
211
Rep 3,288
Drives: anything given a chance
This smacks of advertising, although I understand some people get unduly passionate about tunes for some reason. The anecdotal claims are a concern though.
06-18-2012, 01:32 PM | #12 |
82
Rep 251
then if your planning on tuning during warranty, you should find a guy who knows how to remove that code. If thats true, its impossible to tune without a code thrown and the signal interceptor is your best bet but will ruin your engine in the long run. There is no other way! unless you are willing to reprogram you ECU each time for a Hefty cost.
06-28-2012, 08:23 PM | #13 | |
202
Rep 2,740
The ECU logs all sorts of data, if BMW want's to screw you over a tune then they can easily do if they want. |
12-15-2013, 12:03 AM | #14 | |
125
Rep 703
Drives: 2014 328d
2014 328d SportLine
12-15-2013, 01:23 AM | #15 |
52
Rep 388
It's three times the cost of a JB4.
There should be some proof provided to show it is safe and reliable and performing to lure people into spending the extra money I saw the you tubes but I wouldn't know how that compared to a JB4 , AFE, TMC |
12-15-2013, 10:48 PM | #17 |
125
Rep 703
Drives: 2014 328d
I don't have any independent dyno graphs for you to look at to confirm the manufacturers' claims. Take it or leave it at that.
Personally, when it comes to a new BMW under warranty I'm going to get the best possible product I reasonably afford. It's not only about dyno stats, it's not even primarily about dynos for me. I want to protect the engine and I want to decrease my chances of creating problems and possibly having to hassle with the dealership. If I get a 20% boost in power with increased peace of mind, I'm good. For those reasons I've decided to go with one of the high-end piggyback tuners--they include AC Schnitzer, Kelleners Sport, Hartge, and Steinbauer Performance, AFAIK. They're all German and they've all worked for decades very closely with BMW and their products. Will the BMS tuning box give you as much or more power for anywhere from 10-20% of the cost? Yes. Will you have problems with the tune? Probably not. So that might be your choice. Please don't flame me for mine. After weeks of looking into this I've found out that these high-end piggybacks work differently and more naturally increase power than the lower-priced competitors, that they're easier on and safer for the engine and DPF, and that they tend to produce a smoother, more natural (less peaky) acceleration, along with lower toxic emissions out the tailpipe. FYI, the Schnitzer comes with a full engine/drivetrain warranty like Dinan's but it's way expensive ($4-5K). The Steinbauer has comparable technology and it's a lot more affordable, but doesn't currently produce a TB for my car (328D). Same for Hartge, except it's more expensive than the Steinbauer. That leaves my probable choice being Kelleners Sport, and I'm investigating that option with the help of their U.S. distributor Bavarian Auto (Bavauto.com).
2014 328d SportLine
12-16-2013, 01:55 AM | #18 | |
52
Rep 388
There is not much information from users around the other tunes so please keep us updated should you buy Kellner. |
12-16-2013, 09:38 AM | #19 | |||
125
Rep 703
Drives: 2014 328d
Here is the body of the first email: Quote:
2014 328d SportLine
12-16-2013, 11:18 AM | #20 |
52
Rep 388
Found this today no,mention of soldering,but I guess you are talking about the Diesel engine
http://f10.5post.com/forums/showthread.php?t=841010 http://f10.5post.com/forums/showthread.php?t=818356 This is about the N20 Last edited by Ouzzo; 12-16-2013 at 11:45 AM.. |
12-17-2013, 11:27 PM | #21 | |
125
Rep 703
Drives: 2014 328d
2014 328d SportLine
12-27-2013, 06:09 PM | #22 | |
448
Rep 1,372
