      06-12-2012, 08:46 AM   #1
E90SLAM
Supreme Allied Commander
E90SLAM's Avatar
Hong Kong
2063
61,781
Drives: A BBS WHORE
P.U.R.E: 2014 F1 Engine
The P.U.R.E. Corporation have released the first image of a 2014 F1 engine to René Fagnan of Canadian website Auto123.com; these will be all new 1.6l v6 turbo engines. New to F1, P.U.R.E. (Propulsion Universelle et Recuperation d’Energie) are a start up business created by Craig Pollock and backed by private investors. Initially based out of Mecachrome’s facilities, they are now based at the Toyota Motorsport Gmbh’s (TMG) Cologne technical facility. Seeking to exploit the new Engine rules as a route into F1, P.U.R.E. are speculatively developing their own engine, as they do not yet have a team announced as a partner to use the engine. Customers notwithstanding P.U.R.E. are a serious proposition, with Ex-Ferrari and FIA engineer Gilles Simon employed as Technical Director, as well as former Renault Sport MD Christian Contzen acting as a consultant. The engine’s design has been in progress since July 2011 by Simon and his team, mainly using simulation tools although single cylinder testing has also been carried out. With the move to TMG the engine’s major castings have been signed off and ordered, so that testing of a complete engine can be scheduled for July this year. Thereafter, a second generation engine will be ready for the summer of 2013.
In summary the 2014 engine rules mandate a 90-degree V6 engine of 1.6 litres, with a fixed crankshaft axis and chassis/gearbox mounting points. The engine can have a single turbo charger, which must be mounted along the cars centreline. Use of KERS is extended with a greater capacity for the Kinetic system (as used currently) as well as the introduction of a Thermal Energy Recovery System (TERS). Further green initiatives are caps on fuel flow and revs limited to 15,000rpm. Despite having a smaller cubic capacity and fuel allocation, the engine will produce the same maximum power as the current 2.4l V8 engines, albeit only when the Energy Recovery Systems are in use.
Completely unrelated to the technical side of the new regulations, is the Fans concern that the engines won’t sound very good. This is based around view that the engines have a relatively small capacity and additionally have the muffling effect of a turbo charger. This format being akin the WRC engines which do not have a pleasing engine note. But this disregards the F1 engines open exhaust, higher RPM and the aggressive use of the turbocharger itself.
Every engineer I’ve spoken to about the exhaust note has said they will sound good. Okay they are not going to be the same glorious sound of a V12, but they will be far from the dull sound of other small capacity turbocharged racing engines. I recall the sound of the original 1.5l turbo engines from the eighties; they revved far lower than the 2014 engine and still sounded loud and exciting.
Speaking to Auto123.com Gilles Simon commented on the engines sound “The sound of the V6 engine will of course be different. It’ll probably be a bit lower, but I really don’t think it’ll be unexciting for all that. The big turbine will be making a lot of noise, whistling really loudly. No, I the new cars won’t be boring at all”.
http://scarbsf1.wordpress.com/2012/0...014-f1-engine/
      06-12-2012, 08:54 AM   #2
THE TECH
THE TECH's Avatar
329
12,980
Drives: BPMsport 2012 E92 M3
Interesting.
