05-22-2012, 06:03 PM | #1 |
Sameet
![]() 756
Rep 2,541
Drives: AY/B M4 '15
Over analyzing...what's the cure?
This is specifically directed toward situations with girls but general life problems are fine too. I find that I over analyze about girls, family, friends, and especially my car..I'm starting to understand that over analyzing is the definite cause of my depression swings that happen on a daily basis. Serious thread with a serious question. How do you over thinkers deal with it?
05-22-2012, 06:08 PM | #2 |
is probably out riding.
![]() 6064
Rep 2,292
I typically make a spread sheet and try to find patterns that may give me the answer.
05-22-2012, 06:50 PM | #4 |
50
Rep 1,922
Are you OCD or have OCD tendancies?
Either way, there are medical and non-medical solutions that can help you with obsessing over things. Regardless of the situation, you need to take pressure off of it. Read up about stoicism, or how to be a stoic. Life is a roller coaster, you're on the ride, whether you like it or not, once you let go a little, your obsessions will slowly diminish. Also, try to find something to fill your free time with sports, hobby's, gym, maybe go back to school...etc. |
05-22-2012, 08:37 PM | #6 |
![]() ![]() 1089
Rep 1,912
05-22-2012, 08:50 PM | #7 | |
Sameet
![]() 756
Rep 2,541
Drives: AY/B M4 '15
For instance, whenever I get my DP installed by the mechanic I start to worry and over analyze about what the mechanic could forget and in turn, I get nervous as hell that my car will be fucked up forever. Same thing with a girl..I'll be texting her and in my head the convo went awry, but when my friends see it, they say everything is fine. To make matters worse is when I feel that the girl is indirectly ignoring me the next day after our convo, so I start to think, "Ok, I was right and my friends are wrong. This girl definitely got creeped out by me". Get it? |
05-22-2012, 08:51 PM | #8 | |
![]() 73
Rep 1,250
![]() But for OP, there isn't a "cure" other than realizing that you have a tendency to over analyze and trying to avoid it. There are worse problems, it typically isn't a problem unless you're pretty intelligent according to the study that I just made up. Law/engineering/other disciplines reward super analytical people. |
05-22-2012, 08:56 PM | #9 | |
Sameet
![]() 756
Rep 2,541
Drives: AY/B M4 '15
05-22-2012, 09:03 PM | #10 |
![]() 73
Rep 1,250
Yeah I tend to see less of an advantage in pharm/med fields, but at least you're going to get a high paying job regardless. Better to not worry about trying to change your personality IMHO unless it is a serious problem.
05-22-2012, 09:05 PM | #11 | |
Sameet
![]() 756
Rep 2,541
Drives: AY/B M4 '15
Ahhh I know what my problem is, it's just easier said than done. |
05-22-2012, 09:15 PM | #12 |
![]() 15
Rep 236
I stopped being a teenager.
Seriously. Get older and you'll stop caring so much ![]()
2009 Honda S2000 -- 1:59.726 Buttonwillow 13CW (N/A, OEM Aero, RS3); 1:55.792 Buttonwillow 13CW (S/C, aero, RS3)
2008 BMW e92 M3, 6MT, MR/FR, NT-03+M 18x10, JIC Coilovers 2007 Yamaha R6 M-drive retrofit! http://www.m3post.com/forums/showthread.php?t=676825 |
05-22-2012, 09:25 PM | #13 |
220
Rep 2,669
I think OCD and ODD are bullshit.
OP look into Yoga and other ways to calm yourself Its not a "over analyzing" thing, its a not trusting your first solution to the problem. With humans there is no definite answer because you can't control them, and honestly people make poor choices. If you're feeling depressed, don't go at it alone, there is help and if you're seriously having depressing tendencies, find help, its not hard to do. GL |
05-22-2012, 10:00 PM | #14 |
![]() 732
Rep 2,003
Ok, OP, are you ready for some heavy sh*t?
Basically when anyone asks any question, whether its about themselves, why, how, or others, about ANYTHING .. the answer, in the end, the ultimate answer, is only one. Let me explain why there is only one answer, the same answer, to everything, anything you could possibly ask, the whole of existence basically. You ask questions, because you believe knowing the answer will solve you problem. Why do you have a problem, or believe you have one? Because something is causing you discomfort, uneasiness, PAIN. And you believe if you could solve it, the pain would go away and you will be happily ever after. If you only knew the specific answer to that one question, the pain from that would go away, but would all pain go away? Why is this important? Do you believe a painless world exist? Why is this even important. It is my theory ( ![]() But once you have solved this issue, say you suddenly found out how to stop over analyzing, what's next? Well something has to be next.. what is it, pleasure or pain? Then do you keep pursuing pleasure, and avoiding pain? Naturally, yes, what else is there to do? Then you see where the problem arises, as soon as your *next* problem pops up, something that is giving you pain, something you want changed. So do you see? It's just a cycle, you are actually being manipulated, by the world. There is no *seperate* will so to speak. Basically monkey see, monkey do. Then hopefully monkey sees himself doing. That's it, that's all i know. Hope it helps, haha.. |
05-22-2012, 10:18 PM | #15 | |
Sameet
![]() 756
Rep 2,541
Drives: AY/B M4 '15
![]() I have to reread that again. |
05-22-2012, 11:05 PM | #16 | |
![]() ![]() 1089
Rep 1,912
For the record I'm not trying to diagnose you with anything and these cases are always assessed on a scale. The severity of the worry and anxiety usually define the diagnosis. Grimlock- What is the one answer? BTW, your suspicions about human nature are supported by emperical evidence. It is called relative rates of reinforcement |
05-22-2012, 11:23 PM | #17 |
![]() 6
Rep 247
BLINK. Read it. Most of your decision impulses are correct. "Enough" information is usually just as good as "all" the information for most decisions.
That, and if you made the wrong decision, fuck it, whatever. There's usually a way to make it better. Usually...
It's Funseeker! I'm all about the good times!
05-22-2012, 11:36 PM | #18 |
![]() ![]() ![]() 799
Rep 6,934
Drives: 2014 BMW 435i X-drive
Try this excercise
For 1 week Give each thought say 3 min tops of thought Then go with the best option found in those 3 minutes And see how you feel after 1 week It's ok to fuck up We have all fucked up And most of the great success stories we hear about fucked up at one point And remember Outside of sky diving, in most situations, you can afford to make mistakes, and fix them later
05-22-2012, 11:36 PM | #19 | |
![]() 732
Rep 2,003
Now that I think about it, I have no idea. But why did I think I had an idea? ..maybe I 'felt' it, I dunno.. Ok, I don't know THE answer, but I would hypothesise that there is one answer for many different questions, or in other words, there is a structure to logic, kinda of like, if you know what is happening on the sub-atomic scale, then molecular, then cellular, then in a living organism .. that things have order. Logic can be used to 'order' knowledge to fit together, basically that the world makes sense rather than doesn't. Not really saying anything I know, but at the same time I can't not say it. Forget it, I am just as confused ![]() |
05-22-2012, 11:41 PM | #20 | |
![]() 165
Rep 1,523
05-22-2012, 11:49 PM | #21 | |
![]() 732
Rep 2,003
I can't say I know any of those philosophers.. I don't follow any particular school, sometimes someone says something that sounds correct, then you pick up on it if you are inclined to pay attention to these things. Some guy here had a signature "It all works out in the end. If it hasn't worked out, then it's not the end." My take, very reassuring, but then its also very very dour. Kinda like it won't hurt, but it won't feel good either. Neither here nor there. Seems like it contains something, but before you see it complete materialize it dissapears just as it appeared. Very strange. |
05-23-2012, 12:10 AM | #22 | ||
![]() 2071
Rep 4,272
Drives: BMW G80 M3
"I used to sit here and do nothing and regret it for the rest of the day. So now I will do the opposite and I will do something!" ![]() In all seriousness (and I'm only half joking with that video) - let go. Learn to let go. Your first instinct is almost always correct; go with it and end the thought process right there. If it wasn't right humans probably wouldn't exist as a species for obvious reasons. Filling your head with half-assed scenarios isn't helping you, quite the contrary. It's giving you the doubt. Only if you were wrong, go back and think about how it could have been done differently. FYI you do have the ability to control your thought process. Over-protective about your car? Curb a wheel, then you'll be like "ah fuck it" and all that pressure to keep them perfect ... gone. Not saying you should fuck up your whole car but you get the point. IT'S A FRIGGING CAR. That is what it is - you must make yourself see this. Sounds like you put yourself on a pedestal by keeping it perfect and now feel the pressure from others to keep it that way. Well guess what - you can put the pedestal where you want it to be. Stop being directed by others! And if none of that shit helps - a beer or two usually takes the edge off my thoughts. Nullifies my higher/intricate thinking process. ![]() Edit: Observe my insightful posts in the drunk thread (more than 2 beers tho): Quote:
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT Last edited by CJ421; 05-23-2012 at 12:16 AM.. |
