BMW 3-Series (E90 E92) Forum
Assistance Screens
06-06-2007, 06:48 PM | #1 |
Rep 8
Assistance Screens
My iDrive screen is split into 2 parts. One being 2/3rds and the other part obviously 1/3rd. I have my Sat Nav on the 1/3rd side of the screen but the dealer quickly showed me how to change the Nav to the other side.
I have hunted high and low but cannot find out how to swich the different functions to the different sides of the display. Can anyone help |
06-06-2007, 07:26 PM | #2 | |
Deny everything
219
Rep 11,378
Drives: 2006 330i; 2015 X6, S1000RR
Then press on the idrive knob and you will get a menu of what you can see on that small screen. Move the idrive knob to the left. This will put the focus on the bigger screen. press the idrive knob or select menu button to get to the menus and decide what you want on that screen.
I need a drink |
06-07-2007, 10:28 AM | #3 |
Rep 8
Mmm, tried that with no success. If I press the idrive whist in nav on the small screen, the menu just gives me the options to select the view of the nav along with journey information. It does not give me any option to move its position to the larger part of the screen.
06-07-2007, 11:17 PM | #4 | |
17
Rep 1,074
06-08-2007, 06:21 AM | #5 |
21
Rep 1,100
Let me see if I understand you: You want to view the map on the larger screen? And right now you have the map displayed on the right, smaller screen (called the Assistance Window)? Just push Menu to get to the main screen on the larger, main window. Move to the right for Navigation, and use the idrive knob to work down to either Map facing north, Map direction of travel, or map perspective. The map in the assistance window will remain there until you select that window as discussed above in earlier post. Alternatively, using voice command, you can say "assistance window (then fill in what you want, ie, "map facing north", "current position" "off"".
[FONT="Garamond"]2007 E90 335 xi, Monaco Blue, Beige, Prem, Cold, Step, Navi, Sat, iPod
10-30-2007, 10:20 AM | #8 |
11
Rep 40
an other possibility is that the dealer first switched the assistent window the something else than a map view and then used the i-drive knob short cut to go from any large screen that is not the nav screen (e.g entertainment, heating or phone) to the nav screen. Simply hold the the I-drive nob to the right side for more than 2s.
This might have given you the idea that he switched, where it wasn't actually switching by quickly getting the nav screen in the main view. This short cut works for all 4 directions; simply switch between the current main screen and the last main screen of one of the other 3 areas by holding the I-drive knob in the direction of the area (up = phone, right = nav, down = radio and left = heating). Hope this helps... |
