      05-29-2007, 09:28 PM   #1
BMWPower06
A^M=G is nothing w/o the Power of ///M
BMWPower06's Avatar
173
1,817
Drives: ///M5 & ///M3
Some More Physics for you smart guys.
Ok since i got such great help from my last thread here is another
Problem 1:
Ball A is dropped from the top of a building. One second later, ball B is dropped from the same building. Consider the balls while they are both in flight. You may ignore air resistance. Which statements are true about this situation?
True False- Both are in free fall
True False- As time progresses, the difference between their accelerations increases
True False- As time progresses, the distance between them stays constant
True False- As time progresses, the difference between their velocities decreases
True False- Ball B will hit the ground after ball A
Problem 2:
You bring a large cannon along with you on a voyage to a distant planet. You set the cannon on a high cliff and you fire a cannonball horizontally off the cliff into an ocean. The cannonball follows projectile motion until it splashes into the water. Which of the following factors will determine the time that the cannonball is in flight? You should ignore atmospheric ("air") resistance.
yes no- height of cliff
yes no- mass of cannonball
yes no- planet's acceleration due to gravity
yes no- initial velocity of cannonball
yes no- radius of cannonball
Problem 3:
Three forces in the x-y plane act on a 4.50 kg mass: 15.10 N directed at 51o, 9.00 N directed at 142o, and 5.60 N directed at 219o. All angles are measured from the positive x-axis, with positive angles in the Counter-Clockwise direction. Calculate the magnitude of the acceleration.
I got the answer for this: 3.086 m/s^2
Calculate the direction of the resultant force using the same sign convention as above (in degrees).
But how do i do this?
Thanks Guys
Indianapolis Red BMW ///M5
      05-29-2007, 11:26 PM   #2
Josh49
262
6,664
Drives: E90 325xi
This stuff is easy.. If no one helps you out by tomorrow when I get to work, I'll help you out then..
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER.
      05-29-2007, 11:35 PM   #3
BMWPower06
BMWPower06's Avatar
173
1,817
got the first 2. Still need number 3 and this:
A fire helicopter carries a 561 kg bucket of water at the end of a 24.9 m long cable. Flying back from a fire at a constant speed of 43.6 m/s, the cable makes an angle of 48.4° with respect to the vertical. Determine the force of air resistance on the bucket.
and this:
A 2016-kg elevator moves with an upward acceleration of 1.86 m/s2. What is the tension in the cable that supports the elevator?
      05-29-2007, 11:38 PM   #4
ward
163
6,158
Drives: F
problem 3 is just a trigonometery, vector adding type question
      05-29-2007, 11:47 PM   #5
BMWPower06
BMWPower06's Avatar
173
1,817
yea i just dunno how to find the angle.
      05-29-2007, 11:55 PM   #6
ward
163
6,158
Drives: F
use trig to break each vector into X and Y componants
then you can add them easily
you know the length of the hypotenuse of the triangle and one of the angles so you can find the length of the other 2 sides (which are the x,y componants)
what grade or level is this phyiscs BTW?
      05-29-2007, 11:56 PM   #7
ward
163
6,158
Drives: F
and this:
f=m*a
f=2016*1.86
      05-29-2007, 11:59 PM   #8
BMWPower06
BMWPower06's Avatar
173
1,817
f=m*a
f=2016*1.86
i tried that, it said it was wrong...
      05-30-2007, 12:01 AM   #9
BMWPower06
BMWPower06's Avatar
173
1,817
yea i got the x,y components and i got the first part. I dont know how to do the second part of the question, which is asking for the degree of the angle.
This is level one college physics
      05-30-2007, 12:02 AM   #10
ward
163
6,158
Drives: F
hmm do they give you any other info?
not sure what the difference is between force and tension? is tension like the force per area of the cable?
alot ot times they F with the units on problems to make it harder too, maybe that's part of it?
      05-30-2007, 12:02 AM   #11
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
374
7,369
Drives: 2006 E90
my brother is a chemistry/physics teacher....i'm sure he knows.
but me......i got a C+ in physics.....
      05-30-2007, 12:03 AM   #12
ward
163
6,158
Drives: F
for the degree of the angle, you just have to do the first part backwards,
you have the X and Y componants, (2 sides of the triangle) use trig to find the angle
it's another f=ma question
      05-30-2007, 12:13 AM   #13
BMWPower06
BMWPower06's Avatar
173
1,817
which angle is it tho? This is what ive drawn, and ive already gotten the X,Y components.
      05-30-2007, 12:16 AM   #14
John
John's Avatar
57
960
Drives: E90 325i
#3
i got -.4315 for accel in x direction
3.05592 for y direction
magnitude is like you got 3.086
angle i got is 98.038
give that a shot
E90post Project 325i
www.creativeautoworks.com
James@creativeautoworks.com
858.279.8900
      05-30-2007, 12:19 AM   #15
BMWPower06
BMWPower06's Avatar
173
1,817
i got it, it was F=MA then F + MG
but still stuck on the other one
      05-30-2007, 12:20 AM   #16
BMWPower06
BMWPower06's Avatar
173
1,817
Originally Posted by John View Post
i got .4315 for accel, try that
for which problem? and how?
      05-30-2007, 12:23 AM   #17
John
John's Avatar
57
960
Drives: E90 325i
sorry, look at my edited post above
858.279.8900
      05-30-2007, 12:33 AM   #18
BMWPower06
BMWPower06's Avatar
173
1,817
#3
give that a shot
God i LOVE this forum. you are right, so howd u get the angle?
      05-30-2007, 12:34 AM   #19
ward
163
6,158
Drives: F
angles are measured from positive X, so 0 degrees is straight right, 90 degrees is straight up, 180 is left, 270 is down
I'm not sure from your pic which vector is the result, but hopefully this helps
      05-30-2007, 12:35 AM   #20
John
John's Avatar
57
960
Drives: E90 325i
meh luck
do you have aim, i can better explain it to you on there,
but if you want i can explain in here, let me know
858.279.8900
      05-30-2007, 02:16 AM   #21
Driv3r
Driv3r's Avatar
181
2,355
Drives: 2006 E46 M3 ZCP
2006 325i  [0.00]
So this is level one college physics?? I should be set....not to far from what i learned in physics class actually i learned much of this...this is good news..what college do you attend BTW??
2006 E46 M3 ZCP 6SPD-Interlagos Blue - 6SPD - SSK - AA Headers -AA Tune - Navigation w/ Splashscreen Mod - 3M Crystalline Series 60 - Carbon Splitters - Swissvax Treated - Bridgestone
2012 Yamaha FZ8 - Matte Black/Grey - Michelin Pilot Pure 2CT - Vortex Rear Sets - Yoshimura R-77D & Fender Delete - Spectro Race Oil - GP Reverse Shifting
      05-30-2007, 03:28 AM   #22
BMWPower06
BMWPower06's Avatar
173
1,817
Yea this is about the first week of level one college physics. I go to George Washington University in DC. Where are you going?
