11-23-2011, 05:14 PM | #1 |
134
Rep 571
is 2 300hp engines in a boat the same hp as a 600hp engine
I have been arguing with a friend that 2, 300hp engines is the same HP as one 600hp engine
He thinks that 2, 300 HP engines would only be about 450hp
11-23-2011, 05:21 PM | #4 |
316
Rep 2,874
Wow. You need new friends. I'd suggest looking in the engineering department at your local college.
11-23-2011, 05:27 PM | #5 |
Canada FTW.
199
Rep 519
The math CANNOT be done exactly like that, but your friend is def stupid.
The output of 300 HP won't be the same as a 600HP, as different factors come into hand. but still, DEF not 450 HP. He is high as a kite. |
11-23-2011, 05:27 PM | #6 |
134
Rep 571
I dont know how else to explain it to him
He thinks that a boat with 20 5HP motors would not have the same pulling power as one 100 hp engine it hurts my brain to think about
11-23-2011, 06:21 PM | #9 |
195
Rep 1,105
11-23-2011, 06:25 PM | #10 |
195
Rep 1,105
The output of two identical 300 hp engines is 600hp unless you somehow have them geared to a common output shaft that isn't in line with the other two output shafts. Then you might have a little gearing loss. That isn't generally the case in boats- they usually have their own props.
11-23-2011, 06:36 PM | #11 |
385
Rep 4,166
WHOA
mind blowing, I am a belellieverrr
Audi R8 v10 Ford Raptor m3e46freak@yahoo.comfor all euro parts!! ebay/craigslist verified/ m3post/e46fanantics/m3forum/zpost/bimmerforum |
11-23-2011, 06:49 PM | #12 | |
16
Rep 158
Using the same logic, he would be also right if he said a single 100HP would go faster than 20 x 5HP motors mounted to one boat. |
11-23-2011, 06:50 PM | #13 | |
86
Rep 2,291
2jZ + RB26 + 4G63 + LS9 + N54 =
11-23-2011, 06:59 PM | #14 | |
11
Rep 140
2 engines = typically more weight, fuel & double the maintenance...basically more $$$. But looks cooler 1 engine = typically less weight, more fuel efficient, half the maintence...however if it breaks down, basically you're screwed
2006 330i | AW | 6MT | ZSP | LOGIC | ADAPTIVE | PBX
11-23-2011, 07:18 PM | #15 |
134
Rep 571
Im getting really frusterated with my friend he is so sure that he is right. and that you cant just double the HP with 2 motors
Now He is trying to tell me that a truck with 2 300hp motors would be almost 50% less power that 1 600 HP motor
11-23-2011, 07:36 PM | #17 |
134
Rep 571
^^^ yes exactly
11-23-2011, 08:34 PM | #21 |
72
Rep 338
11-23-2011, 08:40 PM | #22 | |
240
Rep 4,726
Next Hp = torque x RPM / 5252. So 2 identical engines will double the HP output at any given point. Use a hybrid car as an example, they electric engines stack with the gas engines for much higher HP output.
