      10-12-2011, 08:22 PM   #1
chylld
chylld's Avatar
55
1,025
Drives: G08 iX3
Email alert links don't work in Firefox 7
when i get an email notification for a thread reply, the link has always been bimerpost.com/blah, which automatically changes to 1addicts.com/blah. however, now the bimmerpost.com/blah url doesn't work in ff7 - it gives me a "corrupted content" error.
apparently the most common cause of this ff7 'quirk' is inconsistent line breaks in the response header.
are any of the mods/techs capable of fixing this? or are ff7 users forever destined to correct the url to 1addicts.com manually?
      10-14-2011, 01:18 PM   #2
hyde
hyde's Avatar
649
1,838
Drives: 2024 X3m40i
One more here
Basically the problem with this is probably something wrong at Bimmerpost end not xbimmers. The link that comes with e-mail is targeting bimmerpost.com/forums
and it seems like the server does not understand and direct the visitor to correct site due to goto=newpost attribute.
http://www.bimmerpost.com/forums/sho...7&goto=newpost
After receiving corrupt content message, you can still go to your topic by removing &goto=newpost and then bimmerpost will direct it to xbimmers.
http://www.bimmerpost.com/forums/sho...d.php?t=597997
      10-25-2011, 08:31 AM   #3
bmwmick
bmwmick's Avatar
18
237
Drives: '97 Z3,'11 Z4 35i,'90 C4 Vette
Corrupted Content
I had posted this above when my search turned up nothing when I searched
here for the error message.
It seems the forums are using a non-standard way of sending URLś via the notification Emails. Fire Fox flags the URL as "Corrupted Content Error" , "The page you are trying to view cannot be shown because an error in the data transmission was detected.Please contact the website owners to inform them of this problem" and will not load the page. They consider it a security violation to have two redirects or two locations in one URL.
This began with FF 7.0 when they closed this security hole.
To get around the failure to load, simply remove the last part of the URL ie:
http://www.bimmerpost.com/forums/sho...5&goto=newpost
Remove everything after 564325 and it will work normally.
http://www.bimmerpost.com/forums/sho...d.php?t=564325
Just an FYI for FF users.
Mick
2011 35i 6-speed, ///M Sport, Deep Sea Blue, Black leather, Carbon trim, Cold Weather package, Premium package, 6CD changer. Delivered 7/15/11. Michelin Pilot SuperSport tires 10/24/12
Tucson,AZ/Santa Paula,CA
      10-25-2011, 11:21 AM   #4
hyde
hyde's Avatar
649
1,838
Drives: 2024 X3m40i
You mean the problem doesn't exist with IE? If this is a bug we should just report it over at mozilla.
      10-25-2011, 02:25 PM   #5
bmwmick
bmwmick's Avatar
18
237
I went to Mozilla first, here is their answer:
There are two location redirects sent by the server on that request and Firefox doesn't allow that.
http://www.bimmerpost.com/forums/sho...1&goto=newpost
Location: http://e89.zpost.com/forums/showthre...1&goto=newpost
Location: http://www.bimmerpost.com/forums/sho...1#post10568611
If you leave out the &goto=newpost then only one redirect is sent and it works.
If you click the above link that has a trailing ')' then that also makes the server send only one redirect because that link is no longer valid.
IE has not closed this hole.......yet.
Here is a Bimmerpost answer:
Thanks for bringing this to my attention. Unfortunately, I can't explain why firefox would decide to handle links in this way but of course it is their prerogative. It seems the only solution would be to use a different browser as obviously when you follow that example link you would want to link into e89.zpost.com and not any other bimmerpost site, and so the server properly corrects the link for you.
Mick
      11-17-2011, 10:14 PM   #6
chylld
chylld's Avatar
55
1,025
Drives: G08 iX3
pathetic responses on both fronts.
1) bimmerpost should fix their forum.
2) firefox should have issued a warning with an option to continue, rather than a hard stop.
      01-14-2012, 01:44 PM   #7
bmwmick
bmwmick's Avatar
18
237
The Forum may be fixed....
Today, the Email notification links seem to work. No Corrupted Content Error.
I'm now running FF 9.0.1 FF may have 'broken' their code to make it fail like IE does.
Mick
      01-16-2012, 03:11 AM   #8
skinrock
Agent Smith
skinrock's Avatar
280
3,344
Drives: 2016 i8
2016 BMW i8  [10.00]
It's not really fixed. If you're not seeing it, then yes, Mozilla must have changed Firefox. I still get the error in Chrome. The simple fact is, Bimmerpost is doing something it shouldn't. It's sending 2 header redirects (one to send you to the right domain and another to figure out what the newest post is).
Whether or not the browser stops altogether is up to the browser developers. But in reality, the links should either be from the proper domain or it should only do one redirect (i.e. redirect from bimmerpost.com to the correct forum domain and parse the "goto=newpost" in the same call, not do another redirect just to find the newest post).
The i8 needs a V8 amirite?
