2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Boost gauge installed
      09-06-2011, 08:25 PM   #1
Edman951
Edman951's Avatar
50
287
Drives: 2014 i3, Capparis White
Always love having a boost gauge on my turbo cars.
I did a simple mounting setup. so it wont affect the cars interior. (drill the dash and damages etc.)
i mounted it on the wiper arm, with a tie wrap. yup it may be getto, but it works, and i can take it off without any visible damage to the cars interior in 5 minutes.
I got a carbon gauge pod to keep it all clean, and wrapped the cables with a cable sleeve.
The complicated part was getting the signal.
Our cars don't have, (at least from what i found) a pressure source to tap off of to get a boost signal. if you tap off any of the vacuum hoses in the engine compartment, you get a continuas 10inch of vacuum, this is from the electric vacuum pump.
The only place i found i could get a easily accessible pressure source was on the drive side intercooler that was a pressure sensor prethrottle body. see item 11 in the diagram.
Not the best place, as you normally want it in the intake manifold to see exactly what the motor see's, but what can i say, i didn't want to get too deep into the engine and removing lots of parts to get to the intake manifolds.
I made a simple adaptor plate that fit between the intercooler and the pressure sensor. with the gauge tube tapping into the plate.
Don't have a picture of it, as its installed.
Here are a few pics of my simple setup.
Current, i3 Capparis White, Lodge interior
Ex- F10 550i Xdrive M sport, white
Ex- trade-in 2008 E90 M3
Ickdeep5726.00
      09-06-2011, 08:29 PM   #2
Edman951
Edman951's Avatar
50
287
BTW,
Someone needs to find a way to get the ecu's boost signal to display in the heads up display.
That would be hot.
Ickdeep5726.00
      09-06-2011, 09:30 PM   #3
TheStig
TheStig's Avatar
52
794
Drives: Alot of everything.
Nice!
Gone But Not forgotten:
-07 Shelby GT500 W/ Full Bolt on E85
-08 335i 6MT W/ Full Bolt On E85/Meth
-08 M3 DCT W/ Full Exhaust / Tune
-13 B8 Audi S4 APR Stage 2+
      09-07-2011, 06:43 AM   #4
Mattar
Mattar's Avatar
Saudi Arabia
11
58
Drives: F10 M5
wish this can be done to our cars
http://www.m3post.com/forums/showthread.php?t=518736
      09-07-2011, 10:24 AM   #5
37
977
Drives: 991TTs
Originally Posted by Mattar View Post
which this can be done to our cars
it can!
http://radar-mirror.com/AD_BMW.html
      09-07-2011, 10:56 AM   #6
alextremo
49
966
Drives: F10 550i
Nice work! Interesting you couldn't find a vacuum hose for boost...
I had a vent gauge installed on my last car and loved it, emailed them to get them to build one for this car but haven't heard back.
http://www.e90post.com/forums/showthread.php?t=504585
Some of the piggyback tuners have hijacked the canbus network to control the gauges on the instument cluster, so I would imagine HUD is not impossible.
      02-22-2012, 03:58 PM   #7
Jmo550
18
232
Drives: 15' X5
Hey I'm having trouble seeing which Vacuum tube I could use . I understand it's on the driver side . But is the hose the one next to the hose that has the painted mark on it ? Or is it even lower down the inter cooler ? Thanks
2015 BLK/BLK X5 35i - M sport
997.1 GT3
      02-22-2012, 06:13 PM   #8
XDEEDUBBX
XDEEDUBBX's Avatar
64
1,715
Drives: 535I
very nice! thanks
      02-22-2012, 07:24 PM   #9
Jmo550
18
232
Drives: 15' X5
anyone i need help !
997.1 GT3
      02-25-2012, 02:25 PM   #10
Edman951
Edman951's Avatar
50
287
I redid my connection a few months back.
I used a map sensor adaptor, that people use in the import world, and machined it to work on my 550i.
This is required to get a hose tap to get a pressure signal.
Since i did it on the intercooler side, pre-throttle body, i only see boost, and no vacuum reading.
      11-14-2017, 11:53 PM   #11
BDJL
10
Drives: 2011 550i 6MT, 2017 X1 M Sport
Where did you route the air line through the firewall? I'm thinking I need one of these, the only concern I have is when I add meth will any moisture get in the line?
      12-03-2017, 08:27 PM   #12
gestut
34
Drives: 2015 M5
the item 11 is on both sides of the inter cooler so did you tap from both the inter coolers ? A and B? and what boost numbers do you see
thx
      12-08-2017, 06:56 AM   #13
WaqasRiyami
Oman
46
42
Drives: BMW F10 ( 535i )
very nice! thanks
5post
